how good will a small cosworth turbo be for my ZT
i have been offerd a small turbo from an escos and wonderd how suited it will be for my 2.1 zetec turbo 8.2:1 c/r and omex 130ps cams with up to 22psi boost
How shit are the escort rs turbo exhaust manifolds?
i have been thinking of choping up a 200sx tublar exhaust manifold to fit to my car
why the fuck will my compression ratio be the limiting factor?
i have rods and forged pistons and i would trust it to use 22psi at 9.5:1 with out fucking up with all the good components it was built with
Cake lover!
I thought the small turbo cossie was T25? if thats the case i wouldn't bother mate. Try getting a T28 off a 200sx/pulsar they don't go for much and will get alot better results than T25.
Just look at the FRS to get over 290bhp they are moving on to GT28's and thats a more nodern T25 with lots of gucci bits[my tecnical term].
Ask me a question!
With a ZT you already have a good tourqe to be able to pull away with.
A quick spin up from a small Turbo is the last thing you want.
A Small Turbo Esc Cos unit is shite!
T35 front compressor housing and compressor wheel onto a T3 core with 360bearing and a 48 housing is what you need
Only my opinion so dont bother listening
ahh thanks for your help mate
so what do i ask for when ordering the above turbo so the bloke on the other end can understand exactly what i want
and any advantage of what type of ex housing ie cosie or erst elbo type?
and wont the 48 exhaust housing limit my top end of the rev range?
at the minuite i have a smoking turbo that must of had a shite rebuild because its fooked after 6 weeks
and its made of
48 exhaust housing with elbow
t34 compressor wheel but the housing is from a t3 and has been milled out so the wheel will fit in the hole
sounds simular to the above turbo jano was on about
but why the fuck would you mill out the compressor housing to fit over a t34 wheel?
and its made of
Ask me a question!
Just to add:-
If the compressor housing had been milled out to take a larger wheel the effects of this are that the ACT will be alot higher as the A/r of the housing is not correct for the wheel.
Alot of Turbo re-conditioners will mill out 2wd housings and fit 4x4 wheels.
Or even use std T3 housing and mill it out for 4x4 etc...
This is not the way to build a Turbo which will last
HTH
HTH
big_Rad
15-09-2017 09:36 AM
