Need some RS Turbo help--Re,fueling
#41
it will put it into purely mechanical fueling, basically tuening it into K-Jetronic rther than ke-jetronic.
i wouldnt want to rag the arse off it with it unplugged, but its fine to disconnecta dn go for a drive to see if it makes a difference.
if it fixed it your problem is electrical
if it doesnt your problem is mechanical.
i'm deffo thinking airleak (bd one) or fooked metering head. is the dump valve a proper twinpston jobby? get it off now and block the hole up see if that make sa difference.
as for adjusting fuel pressure, MFi works on pressure differentials, its not the same as EFi where yuo tweak a screw and the pressure at the injectors goes up/down.
you have CONSTANT fuel supply to the injectors (theyre always on) and you increase/decrease fueling by increasing/decreasing the pressure of the fuel delivered to them. you get the base fuel pressure into the metering head (about 5bar i think) and theres a kinda gate/slot that opens up more as the flap in the metering head goes down which lets more fuel through to the injectors.
air hits flap - flap moves - slot opens up more - more fuel gets through
#48
if it went to trem, theyre good so i hear so they likely did all the simple tests we can sugest and pointed the finger at the metering head.
you really just wanna replace it with a known good one, the fuel distributors on them are not easily serviceable
#54
Chasing Radders
Originally Posted by andyt
just waxoiled mine mate well the batt tray and scuttle pannel might px it for a 650 quad (road legal) of flebay
Fuck that, keep it. Have you ever riden a quad on the road
#57
#60
Chasing Radders
Originally Posted by tonyk
Tiff, mine done the same before packing in. Eventually even a bump start wont work. Metering head was replaced and it was ok.
Cheers Tony
#63
Chasing Radders
Right then, all sorted. Got it booked in with Karl next week so i need to source a good Metering head to be with me buy next week
Does anyone have Gups number?
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
