tachometer
is there any way of testing how accurate they are?
Can you put a known voltage knowing it should read a certain rpm and check it reads it or is it a bit more complicated?
ahh tricky one to answer,,, the standard rev counter at them sort of revs would be accurate, but if you have piggy backed another rev counter off the standard wires then it might be upsetting the standard one!
you can measure the revs with a tidy timing light/strobe techo, hand held tacho
trev27
Escort MK 5 / MK 6
13
Apr 9, 2022 10:10 PM
