Really need help
Old Aug 9, 2004 | 04:52 PM
avengerpenguin's Avatar
avengerpenguin
Default Really need help
Fitted stage 3 bits at the weekend, when i started the car, it was missing on cylinder no 4 and white/grey smoke pouring out the back that stinks of fuel. I have swapped the injector and plugs for that cylinder and also checked for a spark with the ht lead out still no joy, please help as i was hoping to have it ready for Rally Super Car day on sat
Old Aug 9, 2004 | 05:16 PM
St3V3_C's Avatar
St3V3_C
So you had a spark?
You say changed plug - spark plug or injector plug?
Old Aug 9, 2004 | 05:18 PM
Spiky's Avatar
Spiky
when i fitted all my stage 3 bit's the only place i drove was to the tuners to get the fueling sorted.
have you put a 3bar map sensor on?????
check it is ok???? wire's on and vacum is ok....
Old Aug 9, 2004 | 05:24 PM
avengerpenguin
I swapped the injector and spark plug over to a different cylinder and the problem was still with cyl 4. I have put map sensor on I will have to check that, will it run with the standard map sensor on just to check?
Old Aug 9, 2004 | 05:48 PM
St3V3_C's Avatar
St3V3_C
Give me a call mate, I'll come and have a look for you if you want 07977 599 669
