Fuel System Modification
Old Jun 2, 2006 | 07:26 PM
originalcabbie's Avatar
originalcabbie
Default Fuel System Modification
Gents/Ladies,
I have seen the modded cars on this site and I am looking to gain more power from my KEJet S1. I had it set up at PJ Motorsport and I should be running in the region of 300bhp with all the mods but PJ could only squeeze 190 safely although it does smell of fuel on overrun????
I keep seeing the fueling systems that are being put on all the cars which are heavily modified and with the modifications to my engine I should be easily in the 250bhp region. Brief spec:
Big valve head
modified throttle body (Bigger)
lightened and balanced
steel bottom end
newman cam and solid lifters
5 th injector setup (which is a MSD one but found out it was used with a cold start injector not a cossie green)
KE Jet
20 psi chip although peaked on the dyno at 26psi
cossie fuel pump
stage 2 gearbox
I have seen a number of specs that easily get over 200 bhp but I just can't reach it. PJ said I was getting enough air but not enough fuel.
Any of you have any suggestions??? I tried in the tech section but its a bit slow!
Stu @ MSD you may know the car, its got your stickers all over it!! pm me as Id like to know what sorta power you think it should be pulling.
CheeRS
Old Jun 2, 2006 | 07:38 PM
bud-weis's Avatar
bud-weis
Football Cwazy
get in touch with Karl Norris
www.norrismotorsport.co.uk
he is a bit special when it comes to RST's
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 27, 2015 04:55 AM
Bransby
Sep 21, 2015 05:29 PM
coscor86
Sep 20, 2015 01:21 PM
ST-170
Sep 4, 2015 11:02 AM
