ENGINE BREATHER
Old May 31, 2006 | 06:58 PM
a7fco's Avatar
a7fco
Default ENGINE BREATHER
just a couple of questions my breather tank has 4 outlets on the top and one on the bottom
1 for the little k&n
2 for the rocker box breather
3 for the kidney box
4 ? does this go to the 17mm bolt under the turbo just above the sump? do i just get it drilled out and weld a pipe to it or does someone make a replacement?
and last of all the one at the bottom of the tank do i just block this off and use it to drain out the shit ?
thank guys
Old May 31, 2006 | 09:00 PM
a7fco's Avatar
a7fco
please anybody
Old May 31, 2006 | 10:04 PM
Basky's Avatar
Basky
got any pics
Old Jun 1, 2006 | 05:45 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
remove the blanking bolt from under the turbo,and screw a fitting into it so you can connect the hose.no need to drill and weld.as for the other questions,would need a pic to help with pipe fitting.
RUBY123
Oct 22, 2023 12:04 PM
mint_s2
Sep 2, 2015 08:58 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
