help with pro alloy rs500 cooler fitting please
all i need to know is the modification plate that bolts to standard
radisator mounting, and then the cooler and rad bolt to underside of it
is that correct, and am i right in thinking 1 rubber on each end of both
rad and cooler, cheers peeps
there are 2 bolt holes pretty close together in the chassis.
you will have to get a rectangle shaped plate made up,alloy or steel and drill 2 holes in it.
this plate gets bolted to the chassis and then the radiator bolts to the plate.
this moves the radiator closer to the engineso to give you enough room to fit the i/c in and the rad.
590 BHP/Ton
track.focus'd
12-08-2015 05:53 PM
