Had my cossie set-up at Marks yesterday -Quick Update
#42
Originally Posted by Andreas
Originally Posted by Stu @ M Developments
Glad your happy Rich, was wondering how you got on with my first ever off the shelf Greys chip, great to read all is well and your a happy man.
Whats needed for this bar the cams and the greys?
Is it still standard comp?
Standard head ports
You need an 044 feul pump and i would recommend decent suspension to get the power dwon really
#43
Originally Posted by wimwerf
nice.....
you have to change your name nou...
cossierich400....
cossierich400....
Think i will just change my name to cossierich becuase im not sure of the power really. With standards ports on my head i wont have reached the magical 400bhp. This was an experiement for myself, Mark and Stu really.
Mark has never done a greys conversion on a standard head before.
I have the 1st off the shelf greys chip from Stu
I can deffo confirm that it works fine but im going to have to change my -31 for a -34 because my 31 is at full preload
#48
Originally Posted by cossierich330
This was an experiement for myself, Mark and Stu really. Mark has never done a greys conversion on a standard head before.
I have mapped hundreds of conversions like this obvioiusly, but have always maintained we will never do greys conversions "Off the shelf" as we believe 380+bhp to be too much to ask of a DIY fitment on a potentially 20+year old engine, harness and fuel system. The possible problems are many and we quite simply do not wish to have our name muddied when things go wrong and engines fail because silly little things that are wrong with cars, fuel filters, fuel regulators, wrong plugs, squashed fuel lines, CR totally wrong, injectors not modified properly etc etc... All these will spell definate meltdown if not checked professionally with wideband and det equip and we would naturally be the first in line for a portion of blame. lol
We decided recently that if you are having a well known pro tuner do the fitting, setting up and checking, we will be happy to supply you some really good management software. Rich was the first, chosing Mark to do the fitting for him who we are obviously happy with as ive heard on the grapevine he knows a little about these YB Cosworth things.
We will do this conversion mail order now for all level's of ECU and closed loop is also available (Which Rich incidentally has NOT got due to being on L6)
#50
PF Idiot Sniper
this sounds great
after i fit my 500 ic it might be the next step forward. whats the limit of a T34 then? I see you have a .55 and i have a .48
I already have the quaife diff, recon box, alcon 6 paddle and a BD10 inlet so dont need much to convert...hmmm so much for leaving my car as it is
#51
Originally Posted by Lambchop
this sounds great
As Stu put it to me: the .48 gives the greatest mid range torque. The .63 gives the greatest top end. the .55 is the best compromise of the 2
#53
stick with the .48 then, but i have been imformed at the boost i am running they have a tendancy to crack. When i took my .48 off there were actually 3 little cracks appearing 1 around the wastegaste penny hole. and that was at 1.7 bar on greens.
#55
Originally Posted by Sexy-RS
But Helen Sat is the Epsom DERBY you not coming then? Bit of horse racing betting and lots of booze
Plus you will be hungover from the friday night out after ladies day
Got to get the car right hun Otherwise i'll be waitinbg another month to get back over to Mark's as we have shows and dave working for the weekends after next, want the car right for Dorset
We still be out on Friday night
#61
Originally Posted by CossieRich
Stu,
Im pretty sure the more people that read this post, the more will realise that greys and borewash are a thing of the past as well
#64
Football Cwazy
i know what you mean
would like to see the difference between your spec and mine with regards to cam and turbo,
i am organising a RR day,but it's a bit of a trek for you? top of GD if your interested
#66
Stu,
#67
Originally Posted by bud-weis
sounds very good
would love to see a dyno chart for your spec
Originally Posted by RS500/104
sounds very good
and i bet you would love to know mine to RICH SO WOULD I
#68
One of the 1st questions i was asked was: you sure you havent got bore wash. I said i wouldnt even be able to tell you if i have because i dont know the symptoms, but im 100% sure i havent because i have a pukka chip
Borewash comes from running massively rich mixtures, especially at idle and cruise. As you know, your running almost perfect Stoiciometry at 14.6:1 and without any help from closed loop circuitry, so you can catagorically state, NO, you are not suffering borewash, in fact, under certain conditions its probably running marginally leaner than they did new. lol
#69
#70
#71
#73
Seeing as my -31 actuator was at full pre-load i bought a -34 and back down to Marks this morning. We managed to get 34 psi, which Mark reckons is easily good enough for me to be in the 380bhp bracket
Very very hot day and my inlet temps were getting high even with the pro-alloy cooler doing its job. Maybe time for water injection to keep ACT's down.
Am over the moon with the chip and Mark setting it all up properly.
Big thanks guys
Big thanks guys
#74
Be good when me you mark go for the next drive to a show will be a drive and very quick !!!!!!
remind me to have a chat about some things on tue i think you will like want i am just about to get rid of
and now i think my NOS kit needs to be sold or USED
just dont want the police to say
