ouch..
Old May 24, 2006 | 02:54 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default ouch..
note to self- when removing the rear wheel bearing on a bmw e30, make sure that you do NOT hit your fingers with a lump hammer
Old May 24, 2006 | 02:57 PM
Dan B's Avatar
Dan B
Very good advice, will have to make a note of that one!
Old May 24, 2006 | 02:58 PM
Graceland's Avatar
Graceland
Team HOTHOT!
and also, its easier to remove the bearing with the rear beam off the car - less chance of hitting your fingers
Fiddy's Avatar
Fiddy
lmao, thats got to hurt
Old May 24, 2006 | 03:02 PM
proper shitty job to do that one on an e30!
Here's me doing one of ours:
89xr2's Avatar
89xr2
Brap!
I think it's better to remember this simple rule, you'll find it applies to most things
'when using a hammer, mallet, end of your ratchet to hit things avoid striking ones fingers with said hitting implement'
Old May 24, 2006 | 03:08 PM
Rene's Avatar
Rene
gotta hurt
Old May 24, 2006 | 03:11 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Bet you turned the air blue with that one, Paul!
Chip, I can't for the life of me work out what's going on in that pic.... I thought wheel bearings just unbolted? Well, except for the ones that manage to weld themselves on, of course.
Which is probably what happened to yours
Old May 24, 2006 | 03:12 PM
Pete.W's Avatar
Pete.W
good advise Paul, been there, done that and got the new finger nail to prove
jay, its a primitive puller, the threaded bar goes through the hub and connects to the back of the bearing, doing up the nut pulls it out.
the heat is just to encourage it, as was mongo whacking it with a hammer at the same time
Old May 24, 2006 | 04:56 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Chip - have you got a picture of the puller from behind the bearing flange? or any other pictures if possible
Old May 24, 2006 | 04:57 PM
xr-stu's Avatar
xr-stu
such a bastard of a job!!!!
the fronts are rediculously easy though!!
SteveH
14
Oct 24, 2008 01:05 PM
