Esc cos suspension
Can peeps please put up pics of their esc cos with spec of their suspension. Mine doesnt sit very level for some reason (lower at the back) So i might get different springs??
Not the best pic but it could do with being an inch lower at the front.
![](https://img.photobucket.com/albums/v122/fezzy2/num2.jpg)
I have a Bilstein sprintline kit on mine and it sits the same as yours two low at the back and two high at the front!
what springs would mine have(don't say bilstein ) and what are the best ones to fit that give the best ride height ?
Dave.
PS the springs are red progresive ones.
Dave.
Did Someone Mention TUV
Originally Posted by ian rst
cant really see yours Paul bit too dark.
I was thinking Armed or eibach springs but thought Armed's didnt really lower it much?
Car height and weight checked.
Photo before set up.
![](https://i4.photobucket.com/albums/y144/kenny55/pictures020.jpg)
Front lowered a shade to give 650kg.
Rear height increased to give 460kg.
Will post new photo tomorow.
(Rear spoiler still not arrived, sills to fitted this week).
Originally Posted by Paul Ripley
What are those wheels doug?
Revolution Millenium edition the best almost Ł1000 I have spent on the bugger can get you a bit of double Doug discount if your intrested in a set
Regards Doug .
Mine has bilstein kit and I believe its pretty much at standard ride height. This pic was taken on a slight incline so is slightly up on that side and is slightly lower when on a flat.
![](https://i29.photobucket.com/albums/c288/TurboCav220/IMG_1246.jpg)
The escos needs that ''front down, rear up'' look in my opinion. I think you can spoil the whole look by lowering too much, and it can sometimes make them look like replicas.
I think Im right in thinking its better for handling to have the front pointing down with the rear slightly higher anyway.
I think i will be getting some eibach springs then, judging by what i have seen they sit the best. thanks lads
A pic from about 4-5 years ago.... when they were newish and new Konis
![](https://img.photobucket.com/albums/0603/Redkop/Cossie/cid_E8AEC428-9FC1-42F4-98C4-BD233ED.jpg)
