ybp build questions....
going to make a start on my engine next week, it run around 400bhp (cossie ybp with the squirters) got the pistons, bearings etc.... was going to use a cometic head gasket as i've used a couple in the past & good results with them, thing i keep pondering is what to bolt the head with???
i was going to use arp studs & nuts as i don't thing long studding is really needed at this level, but the only thing that bothers me is i've seen so many 200 blocks crack around head bolt holes (normally the 2nd one in) so my question is, is there a way to prevent this happening? is long studding the answer?
the P.E. cossie engines were standard bolts & a group A headgasket, the guy who used to build the engines said he would build it for me if i wanted (but he said he would prefer a 2.4 crank & rods to use in it)
Times have moved on since P.E. stopped building engines so i thought i would get some other views.
The way I would look at it (DID look at it when my new blocked engine was built) ... Why not go belts n braces?? i.e long stud... If its apart anyway, whats a little more machining while you're at it??
At 400 brake I wouldnt want to cut corners ar worry about reliability...
(I also went for the gen WRC 4 layer gasket, though admitedly they're coin )
I personally would not use the standard bolts UNLESS you don't mind changing the gasket every 8-12k miles (the bolts stretch under high boost application and the head starts to lift) depending on use (obviously if you poodled it around everywhere, then there wouldn't be an issue ). Obviously not an issue for someone as mechanically able as yourself, but those £200s for head-sets soon mount up if you intend on keeping the car. My Escort has done 30k with a WRC gasket / long studs and it has been a case of fit and forget, in view of this, you know what I will recommend.....
Originally Posted by bud-weis
any proof of this mike???
standard head bolts (genuine only) have been recommended to me on lots of occasions,and i'm pretty sure i know of one car using them with nearly 700bhp
PassionFords Creator
also do you torque it straight up
Personally i pull them out one at a time and then put the new one back in to 30ftlb.
Once all are in i tighten them as per the normal procedure. I have a couple of customers with Cometics on big miles (20K+) using this method, yet on my own car i never remember and have to change teh fooking gasket after 10 - 12K
Most people with blown gaskets will admit that when undoing the old bolts to do teh job, 1 or 5 were only finger tight. That is what we are fighting.
if your going to build an engine do it properly its only a bit more machining.you dont need long studs but like mike and stu say if you want to keep your head tight then have them.the more boost the more the head will lift and move around but with proper long studs the head cant move around so no head gasket failure or cracked blocks
Long stud conversion is it only 6 studs that are drilled and tapped deeper into the block so that a greater torque can be used?
Sometimes i wish i was back in engineering so i can do this myself
yes thats right costina the reason the arp ones arent very good is because they still use the original bolt size holes and they still flex.ive got 10 long studs on my nikasil linered cgi block but iv had to use a wrc water pump for clearance hopefully block should be bullet proof
if you think back to the old f1 1.5 turbo engines they where monoblock so no head gasket or bolts so the better the head stays together with the block the better.they used to run upto 5 bar boost in qualifying
I agree 100% with Mike. I advise customers with standard bolts remove and refit new ones every 6000 miles if possible.
just thinking aloud i'd like more discussion,although it's too late for me,my engine is in now
what about headgaskets, i know you hear loads of stories but a couple people have told me that the cometic gasket dosn't work aswell with long studs, how long should a group A gasket last with long studs?
are arp stud & nuts best avoided?
WRC gasket and long studding, if done properly with correct bolts and gasket really is FIT AND FORGET. I never worry about headgaskets any more and in 50,000 miles of running this kind of set up (20k on 515bhp engine and 30k on 477bhp engine), I have NEVER had a head-gasket failure (and on track I have seen water temps as high as 115°C ).
I have heard that long studding could make the block "bend" so that the crankshaft would not fit anymore properly. So that the only way to make sure it is ok, is to sacrifise one headgasket and build the engine up and measure that the crankshaft does line up correctly (if not then make it fit). But this is just what I have heard So I don't know how true this actually is.
nico12
31-12-2015 04:42 PM
07-10-2015 12:56 PM
