cam
Old May 19, 2006 | 10:11 AM
Hrsturbo's Avatar
Hrsturbo
Default cam
Got my newman cam kit through yesterday
Going to order oil seals but do I need new bearings for it??
Do I use normal grease when fitting it?
Also, I ordered the "special" tool, what the hell do I do with it?
Old May 19, 2006 | 11:51 AM
rstdave's Avatar
rstdave
Alright mate, got a newman in mine.....didn't bother changin the seals or bearings tho!! The 'special tool' is for adjustin the solid lifters, as u need to set the clearances between the lifter and the rocker which is a bastard of a job to be honest mate! Best way i found was to put the tool in a vice and clamp it up, before puttin your lifter in it and doin up the allen bolt on the tool to hold the lifter in place while u adjust it. Dunno if you're familiar with fittin solid lifters but u'll need a set of feeler gauges n all to set the clearances as they're tiny!! Hope this helps
Old May 20, 2006 | 10:54 AM
Hrsturbo's Avatar
Hrsturbo
cheers, got some feeler guages somewhere, what clearanes do I need to set?
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
