Cosworth Turbo and oil pressure quesion ???
Old 09-05-2006, 04:19 PM
EscortCosworthUSA
EscortCosworthUSA's Avatar
Default Cosworth Turbo and oil pressure quesion ???
I have a -6 AN fitting on my oil inlet on the normal T34 turbo (esccos) - but I am reading that with too high of oil pressure, it's not so healthy for the turbo seals. I also see on ebay (I know - not the best information site) that there should be a restrictor on the oil inlet to so-called lower the oil pressure to the turbo.
What do the experts think? -6 too big or fine and don't worry about it?
cheers!
Old 09-05-2006, 05:19 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
yes it is restrict it to the same id as the standard fitting
Old 09-05-2006, 05:30 PM
markk
markk's Avatar
way too big pal, it will flood the bearinghousing completely and will bypass the rings, the restrictor should be approx 3mm, mine is less due to a full flow bearing housing.
Old 09-05-2006, 05:53 PM
EscortCosworthUSA
Yikes - I guess I'll get right on that and get it restricted - so about 1/8" or 3 mm then
Thanks for the help!
Old 09-05-2006, 06:26 PM
markk
markk's Avatar
yes that wil be ok
Old 09-05-2006, 06:52 PM
Tony Ryan
Tony Ryan's Avatar
Ironic then that the Ford GpA 909 fitting and pipe is in Dash 6 !
original
30-01-2022 08:20 PM
big_Rad
15-09-2017 09:36 AM
Bailes1992
16-08-2015 07:14 PM
14-08-2015 07:29 AM
Escortdriver1
31-07-2015 02:36 PM
Quick Reply: Cosworth Turbo and oil pressure quesion ???
