Cosworth Amal/boost control valve question . . .
I know that the Amal valve is suppose to click on when you power the car - but mine is not working right - I have low boost and doesn't vary at RPMs, the boost control is not working at all.
I checked the wires going into the valve and get the 12+ volts, what controls the on/off to the amal valve? Ground or positive? My thought is maybe a bad ground to it and not popping the valve, but I don't want the put a separate ground to it if the ECU uses ground to control it.
I tested the valve off a interior battery line and it does click when I give it power, so I know it should work.
By the way - thanks to all that helped me with my low volatge situation before - was a bad ground afterall to the engine.
I think it has a decent ground on the wire, but the wire was a little corroded/blacked when I stripped it and put a new end connector on it - maybe something to that?
i really dont know about escort ecu's (i know v little about sierra's lol) but i think the iscv and amal are on the same circuit so i would guess if it a loom issue both would be effected?
I don't think its the circuit - the ALS valve I have works fine. I might try the old unplug the ECU and replug it in routine and see if it starts working again. Either that or maybe the wire is faulty.
Thanks!
Thanks!
Escortdriver1
31-07-2015 02:36 PM
