Air to air injectors and ALS
Just thinking about this as I'm bored after reading a topic about Petcel boards in technical room last night
Do they connect to the L8 and P8 loom ? And if so how ? Anynone got any pics ? What else is needed apart from obvioulsy L8 or P8.
Air to air - injectors and loom
ALS - modified throttle body and ISCV, Maram shaft (if you want the turbo to last)
I know they both require mapping as well.
Stu I think it time for another technical essay
feel free to move it to technical room once Stu has done his essay
Pectel board goes in the ECU.
Air to air conects to the amal valve wiring on any of the cossie looms.
ALS valve plugs straight into the ISCV plug if you use the modded Webber valve or Mountune valve.
Stu doesn't map Pectel boards. He does it all in the original ECU set up and software.
Originally Posted by Damo V
Air to Air essay already been done mate ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
They connect to the Amal valve plug on the engine loom
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
That easy ? Supprised at that !!!
L8 can't run ALS full stop. Wether it had a Pectel board or not. P8 can and Stu/Kenny make ALS work with the ECU's own software. No board required.
Air to air can be done without a Pectel board. Stu/Kenny make their own controllers. All the Cossie ECUs need either a Pectel board or the controller to run air to air.
mk3ste
17-10-2021 10:09 AM
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
