Long studs...........
Old May 6, 2006 | 07:33 PM
Toe Knee's Avatar
Toe Knee
Default Long studs...........
Whats the process for fitting the studs to the block then the process for doing up the nuts etc after?! and also are the torque settings the same as standard etc or different?!
Just bought a long studded 200block but it needs building up as its bare!!
Old May 6, 2006 | 09:27 PM
TiB's Avatar
TiB
You need to put loctite on them and torque them down to 50ftlb,
Then you need to lube (copperslip etc) all mating faces of the nuts and washers and torque them down to 90ftlb in the usual order
Lee
Old May 6, 2006 | 09:28 PM
TiB's Avatar
TiB
ps,
make absolutely certain that you have cleaned any shite from the threads in the block or you will bottom out the studs and prob crack the block
Old May 6, 2006 | 10:05 PM
Toe Knee's Avatar
Toe Knee
Cheers mate much apreciated
Are they not torqued up the same as the stretch bolts thou?! as you still use 4 stretch bolts with the long studs.
and stretch bolts are done in 3 stages.............
As obviously normally you'd do all the bolts before going to the next stage, if that makes any sense
Old May 6, 2006 | 10:16 PM
TiB's Avatar
TiB
by "usual order i meant 5,6,3,8,4,7,2,9,1,10 type thing, as for getting to the 90 ft lb i usually do them all to 30, then check them all at 30 twice more as the first couple you tighten will now be loose,
once they are all at 30 then i move on to 60ftlb and check again,
then finally do them all to 90 and check,
the 4 outer bolts i use "used" standard head bolts and they are tightened as part of the sequence to the same torques
Lee
mjonathan24
Oct 29, 2015 10:39 PM
A.t.p
Oct 23, 2015 07:54 PM
sridgett
Oct 1, 2015 07:30 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Fil
Sep 30, 2015 12:08 PM
