Please Help ABS problem. Failed MOT
Old May 6, 2006 | 01:52 PM
motherhupit's Avatar
motherhupit
Default Please Help ABS problem. Failed MOT
Cars just failed MOT due to brakes being out of balance. the
front N/S is 200 pounds, = Stays steady on the reading at 200
Front O/S is 100, = Goes upto about 230 and then drops back down to 100
Rear N/S 20 and = slowly goes upto about 20
Rear O/S is 100. = stays steady at 100.
I have bleed system and modulators, checked wheel cylinders and calipers looks like the fault is in the braking circuit that does the Front O/S and Rear N/S, the pedal also does drop a bit when u push it. it drops about an inch before it goes hard. anyone had this problem before i think it could be the ABS modulator for that circuit that is playing up.
PLEASE HELP need to try and get fixed for MOT quick.
The cars a F-reg Mk3 Fiesta 1600 s, and has the rubbish mechanical ABS system think its the same as the XR3i used.
Cheers GUYs ur HELP would be appreicated
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
