f.a.o anyone with SPA oil gauges
Hi
I've just bought a new SPA oil temp/pressure gauge for the cossie and it didn't come with any instructions
Has anyone got the instructions they could email me please
Cheers Spadge...
Cheers Spadge...
Hi Spadge
I've got an instruction book at home I can copy tomorrow and send to you if you like? In fact I might even have a spare booklet ( I've had 2 of these gauges ) I can send you?
Alternatively speak to Tony Taylor at Spa ( T.Taylor@spa-uk.co.uk ) and see if he can email/send some today if it's really urgent?
Realistically with first class post you're not going to get mine till Friday as it will be tomorrows post I can catch
Mike
Mike
tony is really helpful and a top man...
i have booklet if you need it spadge...
you might be able to download it on their site? like you can on the stack site?
if not mate its really easy and could explain it on here no worries
All sorted now fella's thank you
Another couple of questions however
For the oil pressure sender i need an adaptor so i can put it where the oil light switch is, does anyone know the thread size for the sender?
Also for the oil temp i need a threaded sump plug so i can screw the oil temp sender into it? Anyone know where i can get one or i will have a standard one machined.
Cheers again
Spadge...
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Cheers again
Spadge...
Cheers again
Spadge...
Cheers again
Spadge...
I have the same gauge - can't help you with the thread size on the pressure sender ( as I don't know it ) but the Spa temp sender will fit inside a suitably machined sump plug. Mike Rainbird got me one made by his local engineering company as the one in Shrewsbury that I tried were unwilling to do something so radical....
I'll have a look and see if I've still got the modded sump plug if you like as I now have the sender screwed into a boss on the sump.
Also be aware ( if this is an old version of the gauge - i know you said you had no manual? ) that the backlight failing is a known problem that Spa can fix
Mark RS
12-10-2015 06:01 AM
