what happens to the dizzy~?
I will be at MSD soon for a few things
Was just wondering ,what happens to the dizzy after a coil pack conversion.Is it blanked off or left in ?????
it can be blanked yes but this depends what you plan to do with the phase sensor. the coipack conversion still needs the phase input, this can be run off the dizzy as before or taken from the cam.....
not my car, mine runs the coilpacks but has the phase off the dizzy still. these pics are work done by zoo motorsport - http://www.zoomotorsport.co.uk/
Team HOTHOT!
Originally Posted by Alex zvh cabrio
taken out and blocked like u do on the efi set up
is that a standard part nick?
would one replace a standard 2wd item in my 200 block?
would neaten it up a little as i still have the dizzy cap on to keep the phase sensor sealed from water!
you can't use a small turbo escort phase sensor on a weber system,,, not without a converter inline! and the small turbo sensor has a 180 degree stricker, the normal cossie has two striker plates 90 degrees appart
ones hall effect the others inductive
i still have my dizzy in place for the phase.. never bother about removing it as it works fine..
take it i could remove it and fit a the sensor on the rocker or use the small turbo one without conversion if on autronic?
any advantages to these set ups over the normal dizzy?
Originally Posted by GARETH T
matt you can see on this old shot of my engine bay, i turned a piece of alloy down to fit (and cut the top of the dizzy shaft off)
Dont for get the dizzy also drives from the jack shaft to the oil pump...
Ian
wheelwizardrefurbs
23-09-2015 09:14 PM
