Transit van help!!!!
Old Apr 30, 2006 | 05:35 PM
Default Transit van help!!!!
..i got a p plate Transit with the 2.5di 76ps version ...noticed for a long while i slight puddle of water under the van every now and again.....i looked under there today and saw it slightly dripping and a bit damp on the cambelt cover...its got to be water pump...but its not making any weird noises.
My question is what will eventually happen?
Old Apr 30, 2006 | 06:04 PM
DazC's Avatar
DazC
It will eventually leak all it's coolant out at a rather quick rate. Or the bearings will start to go noisy if the water penetrated them.
They are only an hour and a half to change....
Old Apr 30, 2006 | 06:07 PM
Where is the water dripping from though...the gasket?????As there is no fine mist comming from the pulley area???
Old Apr 30, 2006 | 06:10 PM
DazC's Avatar
DazC
Gaskets rarely leak Phil. There is a tell tail hole at the bottom of the water pump. They usually leak water out of there when the inner seal fails.
Old Apr 30, 2006 | 06:15 PM
dave cos4x4's Avatar
dave cos4x4
needs to be fixed soon then Phil.
Old Apr 30, 2006 | 06:21 PM
Daz can you give my step by step instructions please as i will take it off tommorrow vand hope i can get a new one on tuesday. I couldnt see how the cam belt cover comes off???
Old Apr 30, 2006 | 06:23 PM
Chris Honeywell's Avatar
Chris Honeywell
Exactly what happened to mine m8
it was leaking for a year before i got it fixed
Old Apr 30, 2006 | 06:25 PM
The thing is i am about todo about 1k miles will it last???Its only minor dripping??
Chris Honeywell
Also better off getting a garage to do it as im pretty sure the cam belt etc has to come off
Old Apr 30, 2006 | 06:26 PM
Chris Honeywell
Mine did lasted about 6k miles and it only got sorted when me van got MOTd and they told me thats what the problem was
Old Apr 30, 2006 | 06:33 PM
bigal1978's Avatar
bigal1978
mine lasted 10 miles from tell tell drip to ful stop sized on dual carrige way
Old Apr 30, 2006 | 06:36 PM
Does cambelt have to be touched?
Old Apr 30, 2006 | 06:44 PM
DazC's Avatar
DazC
They can be done without removing the cam belt....
Old May 2, 2006 | 02:47 PM
MrMPuk's Avatar
MrMPuk
It could last 20 miles or it could last 2000, it is quite an easy job and can be done without taking the cambelt off.
Old May 2, 2006 | 02:52 PM
All done changed today cheers lads
Old May 2, 2006 | 03:20 PM
Andreas's Avatar
Andreas
Should have put a YB in while you were at it.
Old May 2, 2006 | 04:29 PM
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
Flatlinedan
Sep 18, 2015 12:41 PM
