Brake problem...
Old Apr 26, 2006 | 01:03 PM
RsDarren's Avatar
RsDarren
From: Dewsbury, The parts were they don't abduct their own children!
Default Brake problem...
Haven't used my FRST for around 8-12 months as I've beeen working on it, got it all running the other week and took it for a spin . Very happy with it , but when i brake it pulls left quite heavily (as if only one brake is working on the front!!), but as you continue to brake it levels out????
All i can think of is that when i bled the brakes and re-duiced them (just before i took it off the road 12 months agao!) the ground i was on wasn't level and caused a disprution in the fluid balance???
So, i had the brakes re-bled last week @ Ford. The guy said that all the brakes had been bled bar the front left brake as the bleed nipple was ceased into the caliper (therefore unable to continue!). When i took it home it braked slightly better but stil no way near right
What are your thoughts??? Could it be that the capiper will just need bleeding or could it be something else? ie sticking caliper??
Need to get it sorted as i'm booked in @ stu's in a few weeks!!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
