s2 breaks
Old Apr 24, 2006 | 11:11 PM
blueovalrallyesport's Avatar
blueovalrallyesport
Default s2 breaks
hello everyone i am new to all this but i am ripping my hair out trying to sort out my s2 breaks my problem is the breaks do not stop me as far as i know i have no fluid leaks the only thing i have done is changed the inlet manifold all connections are tight and everything has been put back the way i took it off can anyone help oh yeah fluid is on max aswell ????
Old Apr 24, 2006 | 11:17 PM
SPADGE's Avatar
SPADGE
Default Re: s2 breaks
Sorry but i found that amusing
Have you had any of the calipers or brake pipes off at all?
Not too clued up on on S2's but if they have a servo have you put the vacum pipe back on from the inlet manifold??
Old Apr 24, 2006 | 11:18 PM
SPADGE's Avatar
SPADGE
P.S Welcome to Passionford
Old Apr 24, 2006 | 11:19 PM
NUTS RuS's Avatar
NUTS RuS
Did they work before changing the inlet manifold ?
Oh and welcome to Pf
Old Apr 24, 2006 | 11:23 PM
blueovalrallyesport
Default s2 breaks
no i have no had any calipers off i did re paint the calipers and drums yes they worked before i changed manifold car as been off road all winter i did also put a chrome res cover and cap cover on i pulled the cap cover off earlier and the yellow disc on top of the cap came off with it i put it back on still no luck tho
Old Apr 24, 2006 | 11:24 PM
blueovalrallyesport
Default s2 breaks
i also pulled the vacume pipe off earlier and it relaesed the pressure so there is definatly pressure there !!!
Carlsworth's Avatar
Carlsworth
Former Sponsor
[quote="SPADGE"]
they re going to are they....
try fitting brakes to it instead,.....
Old Apr 24, 2006 | 11:29 PM
blueovalrallyesport
Default s2 breaks
yeah i been told the stock breaks are pants any reccamendations ?
Old Apr 24, 2006 | 11:33 PM
NUTS RuS's Avatar
NUTS RuS
If its been off the road have the discs rusted up a little ?
It will take a short time for that to clear before you get proper grip back.
Or during the rest period the master cylinder could have started to dry out, which can cause the seal to swell or the casing to corrode internally which means the fluid then just pushes past it without doing much.
Have you played with the ABS at all ?
Just banging ideas at you at the moment.
Old Apr 24, 2006 | 11:36 PM
blueovalrallyesport
Default s2 breaks
no not played with it yet the hand break is bang on one notch the locked solid but the light dont come on the dash neither does any abs light ?? is it supposed to it's a g plate 90 spec ?
Old Apr 24, 2006 | 11:45 PM
NUTS RuS's Avatar
NUTS RuS
So it locks solid.... but wont stop you ?
SPADGE's Avatar
SPADGE
One notch then solid fook me i would be surprised if this cars rears wern't locked solid The light should come on on the dash for the ABS assuming its all still there
Old Apr 24, 2006 | 11:47 PM
SPADGE's Avatar
SPADGE
Not everyone uses the handbrake to go round corners mate
I suspect this is a hydraulic problem!
Does the pedal feel firm or does it just go down to the floor?
Old Apr 24, 2006 | 11:53 PM
blueovalrallyesport
Default s2 breaks
when engine is off if i pump break pedal it goes hard but does go down to floor no sudden it goes down gradually when engine is running it goes straight to floor without any effort abs unit is deffo still there if it is working or not is a different matter ??
Old Apr 24, 2006 | 11:59 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you tryed bleeding the system might be air in there
Old Apr 25, 2006 | 12:13 AM
blueovalrallyesport
Default s2 breaks
no thought i would check on here befrore i do anything
Old Apr 25, 2006 | 12:17 AM
antony215's Avatar
antony215
Escort Rs Turbo
Id give that a go mate as it aint going to cost you alot to do then you can rule that out.
Old May 3, 2006 | 09:31 PM
blueovalrallyesport
Default s2 breaks
good news guys and girls my breaks are sorted was air in the system wierd tho dont know how it's happened but there you go thanks for all the replies nice one
Old May 3, 2006 | 09:44 PM
(quote) i did also put a chrome res cover and cap cover on.
Old May 3, 2006 | 09:58 PM
adamS2RST's Avatar
adamS2RST
chowfornow
14
Jan 5, 2019 09:01 PM
155lee
Oct 24, 2015 11:11 AM
