Need a quick answer PLEASE??????
Old Apr 22, 2006 | 02:57 PM
tosh's Avatar
tosh
Default Need a quick answer PLEASE??????
OK sorry to keep asking advise but if someone could answer the following question I would appreciate it.
Question
Is it normal for the crankshaft to be discoloured at the blades next to the big-end bearings, the only way that I can describe it is that they have got a bluey black colouring to them, the same effect that you would get if you tempered a piece of metal i.e.: when you heat it then dip it in water.
I have done a search to see if I could find any photos to compare it with to see if it was normal but could not find anything
Old Apr 22, 2006 | 03:02 PM
Damo V's Avatar
Damo V
Not uncommon, though your one does look like it has got very hot???
Old Apr 22, 2006 | 03:13 PM
tosh's Avatar
tosh
Thanks for the quick reply mate,
I thought that the crank was overheating due to the bearings being to tight, it only had a rebuild back in June 2002 so I was thinking that they might of fitted the wrong size bearings.
the crank was in perfect condition then and only needed a polish, but I dont recall seaing the discolouring then.
Old Apr 22, 2006 | 03:28 PM
radiant red's Avatar
radiant red
you may be onto something with the tight bearings....
i cant think of any other reason but then your car has been reliable?
i rebuilt my engine last year and there mas no exssesive heat marks
Old Apr 22, 2006 | 03:37 PM
tosh's Avatar
tosh
It is reliable or as reliable as cossies go it's not noisey in any way so I presume it's OK but just wanted to check before I put the sump back on.
Not done meny miles since the rebuild eather, so it's not as if it's a high milage thing.
Old Apr 22, 2006 | 04:40 PM
lawnsy's Avatar
lawnsy
my spare crank is like that so ill be keeping an eye on this post
Old Apr 24, 2006 | 11:32 AM
tosh's Avatar
tosh
Anybody else got any views on what causes this just to ease my mind, don't want the crank disintegrating on me
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
