idle
Apr 21, 2006 | 06:28 PM
idle
my mates 4x4 saph when it gets warm it revs up to 2500rpm on idle and wont go down... any thoughts?
Apr 21, 2006 | 06:31 PM
Remove the ISCV and clean it with carb cleaner,should be ok then...
Apr 21, 2006 | 06:38 PM
tried that still didnt work!
Apr 21, 2006 | 07:28 PM
Try disconnecting the idle speed control valve....or possible air leak check all gaskets on the inlet side.
Apr 21, 2006 | 08:41 PM
cheers i'll tell him to give it a go
Apr 21, 2006 | 08:48 PM
Apr 21, 2006 | 08:51 PM
Quote:
Might take quite a bit of cleaning before it'll work right m8.
Apr 22, 2006 | 04:46 PM
cheers he's just disconnected the iscv for the moment
Apr 22, 2006 | 06:00 PM
I did that in my RST, was much better
Apr 22, 2006 | 06:22 PM
if unplugging the ISCV drops the idle down to normal, then chances are it's throttle position sensor adjustment that is wrong.
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
