turbo oil return location on sump?????!!!????.........
#41
1st to 200 without NOS
Originally Posted by heeman10
Know what you mean Martin, but with such a definite response, fancy stating a couple of reasons for it, and reasons for going against my statements above? This is General Discussion after all! ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
sorry for the misunderstanding.
#42
Space was REAL TIGHT on my bike setup and I had hardly any room for oil return. It is at the bottom of the sump
and oil level is just below the bearing core on the turbo but I've had no issues at all with oil consumption/smoking etc.
![Name: oillevel.jpg
Size: 47.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/148090d1502131792-turbo-oil-return-location-on-sump-oillevel.jpg)
Plumb it in where ever it will fit and forget about it
Mark
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Mark
#44
i've also believed turbo oil returns above oil level, reason is cos oil will drain alot faster.
But if a oil return of Breather, then below, so not affected by crank case pressure, and will drain oil.
#45
anyone else.....
thanks for the picture mark, if it works well then i'm sure i wont have a problem, thats what i was told is a good location it works well, faultlessly...
and has done time and time again...
plenty of people on here use paul hills @ EA and they dont have problems, so why should i ?!? we'll see... i'm speaking to him tomoro and i'll see what he makes of all this...
#47
has the simple fact that a liquid finds it's own level escaped you all? ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
but quickly forgot when i was told i'd made a big mistake in having it fitted there
#48
#49
Testing the future
i'm just saying that it doesn't matter if the turbo oil return goes above or below the oil level, as the oil level will be the same whatever.
it's not like if you have the return under the level that it will then build up in the pipe as it will just level out.
i don't think i'm explaining it very well
#50
No,
but different fluids take longer than some to level them selves.
and thats not taking into account of a car moving, and going round corners @ 100+ mph
(G forces), and gravity forces.
Plus the other variable of crank case pressures.
#51
It sounds like I'm being arsey, but I'm just clarifying just what the question is here
#55
The oil will transmit crankcase pressure, yes, but the crankcase won't transmit the oil pressure. That's the key to this discussion/query
![Follow](https://passionford.com/forum/images/smilies/violent13.gif)
#57
The pressure the oil in the sump exerts on the walls of the sump. Pressure in a fluid = density x depth of fluid x gravity. So the deeper the fluid (i.e. the lower down in the sump the oil return fitting is), the greater the pressure being exerted on it is. Say the density of oil is something like 800kg/cubic metre (total guess), the oil in the sump is 100mm deep, and gravity's 9.81 m/s/s, that gives a pressure of 785 Pascals, or 0.008 bar, or around 0.1psi. The oil pressure to the turbo's going to be around 60psi or so, so that 0.1psi doesn't necessarily make a big difference in THAT respect. Bear in mind the crankcase pressure can be added to this pressure.
However, the rate at which the oil drains away to the sump after the turbo does make a difference. The oil return hose is a larger diameter than the oil feed hose to the turbo, and so the pressure isn't as high. The pressure and viscosity of the oil in the sump create a backpressure for the oil trying to drain into the sump under gravity, and so rather than freely draining away from the turbo, I believe it will be pushing stagnant oil down the return hose and into the sump, which I suppose may increase oil pressure in the bearing. Whether that's a good thing or a bad thing I don't know, but those are the principles I'm working to.
#58
I not as high educated like many of you i have my own thinking.
it should not matter where oil return is above or below oil level, the oil return pressure will force oil out maybe slower if under oil level but this is no matter to turbo there will be oil being pushed into turbo so no starvation even under g force.
If return above oil level it can splash ontop of baffle making drag on crank so not too good for high rpm?
crank case pressure be same rate both way? positive crank case valve controls breathering no? could this concern overcomed by using higher pressure oil feed or oil pump?
#59
Testing the future
none of that matters, as the oil return hose is never full. it's only a fraction of the diameter of the drain tube that is used so it has no effect on the bearing
#60
evergreen - I don't think starvation's a question here, it's more the issue of the post-turbo oil draining back to the sump successfully under gravity, rather than being "pushed" back into the sump, as you've suggested would happen. I think by doing that, the oil pressure would be raised a certain amount, though I'm not sure what bearing (excuse the pun!) that would have on the rest of the engine, e.g. oil pump, drag associated with elevated oil pressure, and bearing operation.
foreigneRS - I think what could happen is that even though the drain hose is much bigger than the feed hose, the backpressure would/could cause the return hose to stay full of oil. It depends on crankcase pressure, but all these "ifs" and "buts" are what make me against having an turbo oil return down there at the bottom of the sump. I'd want the peace of mind an elevated return would give.
#61
#62
none of that matters, as the oil return hose is never full. it's only a fraction of the diameter of the drain tube that is used so it has no effect on the bearing ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
#63
Even if the hose isnt full you could still say pressure from the air sealed in it having nowhere to go, if the pipe is above the oil level the air doesnt have to bubble through it first to evacuate the pipe.
#64
Guest
Posts: n/a
Sorry if I've misunderstood the principles behind this, but surely if its BELOW the oil level then oil from the sump will back fill the return pipe to the level of the sump like this;
![](https://img.photobucket.com/albums/v323/matt_J/sump2.jpg)
Wont this cause a restriction to oil coming from the turbo, resulting in poor circulation/feed to the turbo? causing possible damage?
If its like the pic below oil can return un-restricted keeping good flow resulting in less chance of turbo damage, have I missed something? sorry for the simple pics
![](https://img.photobucket.com/albums/v323/matt_J/sump1.jpg)
#65
Matt - That's right, provided there's an equal pressure in the sump and the return hose. Your pictures are good enough to explain part of the situation, glad someone could be bothered!
#67
Dave - Does that affect the height of the return though? Not quite surewhat it is you're pointing out to us there. Was it moved upwards so the oil's returning about the sump oil level?
#68
Guest
Posts: n/a
Matt - That's right, provided there's an equal pressure in the sump and the return hose. Your pictures are good enough to explain part of the situation, glad someone could be bothered! ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Is the pressure from the returning oil enough to overcome the pressure of a sump full of oil trying to fill the pipe to sump level? if that makes sense?
#69
That's just the thing, the pressure of the oil in the return hose is very low, as it's such a large bore compared to the turbo feed hose.
#70
Guest
Posts: n/a
I cant see any plus side to having it above the level
Wouldnt crank case pressure only be a concern for breather systems where the return to sump is gravity fed rather than under pressure?
#73
i see having such big hose will risk air lock and drainage problem like house gutter in heavy rain the down pipe gurgles this would same happen with pulse in turbo making damage?
#74
Guest
Posts: n/a
#75
Originally Posted by Matt J
so we're agreeing that theres not enough pressure in the return hose for it to return to the sump?
Dave - Back in your box!!
evergreen - no, we don't want a pressurised oil return, as the backpressures could hinder oil circulation through the turbo bearings.
#76
The turbo oil return is gravity fed, so we don't want pressure at the bottom acting against the drain.
#77
No it isn't, it also has the pressure head created by the depth of the oil, as it says in one of my replies further up. Viscosity will also add a reactive force to the oil entering the sump from the turbo.
#78
is bad for oil return hose to be pressured so oil should drain out this hose use gravity not forced out; this good for the turbo correct? oil forced out bad for turbo? why?
if oil return is above oil level sump then drain through oil return hose is free it is best this way. if oil return hose smaller and oil forced out then it does not matter if below oil level the oil is pushed out into sump under baffle plate so it ok like this.
#79
Resident Wrestling Legend
returnging the oil above the oil level seems to have been exlained proplery, this way the oil can be let back into the sump under it's own wieght (plus the force at which is it being pumped into the turbo)
oil returns below the oil level have only been done on 2 cars, the 24V granada engine and some sort of audi, everything else seems to have a return above the oil level
at the same time you can't use the dip stick hole to return the oil either
#80
So, the pressure in the crankcase is equal to the pressure in the return pipe, accounting for negligible oil viscosity and changes in crankcase presure, the level of the oil in the return pipe will be almost exactly the same as the sump level, and the pressure in the pipe will be the same. So it makes no difference if you return above or below the oil level for pressure or oil level reasons.
I can do some paintshop pictures if you want.
