zetec tacho???
zetec tacho???
wheres it at?? ive tryed takin a feed from one of the green wires to the ign. module but it only runs on 2 cylinders if u earth it to me tacho??
i was thinkin maybe i need to run it from an alt. feed??
help!!
help!!
if youre running the edis unit, there will be a green wire that comes off the back of the edis plug, wire that to your tacho and viola.
if youre running mondeo managment, some of them have an internal edis or something, so the wire will come from the back of the ecu.
Originally Posted by luke89
cant remeber but sure theres 2 green wires lol , 2+2 =4 so u should have it reading all for cylinders if you can find the other green wire
xr-stu il go check wiring at edis unit think ive tried that before aswell but will make sure!!
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Depends what management you're running - i know on the EEC V management used on the Focus's, the signal wire to the clocks needs 'decoding' and the signal splitting - you can buy something to split the signal from OMEX Technologies for fitting aftermarket tacho's etc.
Hope that helps.
Hope that helps.
mk3ste
17-10-2021 11:09 AM
SMILER258
28-09-2015 10:04 AM
