what sensors do you need for efi rs?
ive got the cps and map sensor what others do i need? can the others be from xr2i or anything or have they got to be rs?
CPS can be from any efi fezzy/3i
Map sensor will have to suit your ECU
As for everything else, but a complete xr2i/3i inlet manifold and your just about sorted
You would only require the FRST ACT sensor and the adapter.
The MAP sensor you have, and presumably the matching OFAB ECU.
The CPS, TPS, CTS, are all the same.
Someone mentioned a phase sensor above, but the CVH does not have one, as its batch fired.
Steve
Steve
Steve
Steve
david - more than likely mate
Best bet is to get the sensor new from Ford, think its about £30 but at least then you'll know it works, not sure about the adaptor, probably Ford again for this part
defo need a frdst act as has been said - my old xr2t palyed silly bugger for 6 months till i changed to one - and ford don't do the adapters, but AFAIK, a plumming shop should be able to help you!
Mark RS
12-10-2015 06:01 AM
