Cosworth oil/water mixing,help please.......*Problem found*
#41
Originally Posted by pee vee
so you filled the WATER header tank up,
and water poured out of the turbo OIL return pipe??
(with turbo removed?)
I dont understand how the turbo is the problem mate
surely water shouldnt pour out of the sump return if you fill the header tank up?
or am i misunderstanding and being stupid
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
I didn't say turbo was removed did I??????
![007](https://passionford.com/forum/images/smilies/bond.gif)
![](https://passionford.com/forum/images/smilies/smile073.gif)
#43
i replied since then
good work mate.. hope you get it fixed soon
#44
ahh i see!!
fook.. thats strange isnt it. must of happened on the last drive before you
put it away then?
glad you found the problem,, not exactly a cheap fix though is it ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
put it away then?
Originally Posted by lookatmasexycossie
fucking hell,.....
never heard of that happening before,....you absolutely positive its that matey????
must be one hell of a fooking crack.....
carl
Took oil feed off turbo,so that eliminates before turbo,took oil return off sump,filled header tank and the water runs out of turbo oil return
#45
Thanks
#46
Former Sponsor
Deffo m8
fuck me,.....
#49
Originally Posted by lloyd
did the turbo come with the water pipes fitted?. i have seen some that have had a longer bolt fitted,and this has caused a hole in the core ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
#50
just because the coolant/oil is coming out of the turbo return means the turbo is fooked??
surely if the sump is already full of water it will suck it up and pump it through the turbo??
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
#52
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Says oil feed pipe was removed,where does it say engine was running??????????
How could it be sucked from sump???????
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
