WE'RE ON THE WAY!! Ring Countdown - NO Days to Go!!!
Old 04-04-2006 | 03:41 PM
  #41
boXXer's Avatar
boXXer
GASH!
i had that powder coat thing done at my local place as he said it was good for high temps on my exhaust manifold, and all it did was burn off slowly. it wont catch alight or anything.
Old 04-04-2006 | 04:01 PM
  #42
big_wig_074's Avatar
big_wig_074
good work,one problem tho!
your cam wheels are blue!get them painted quick before anyone notices!
Old 05-04-2006 | 12:25 AM
  #43
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Wednesday 5th April 1.19am
Not much to write tonight as it's way late and I'm shattered.
Quite a bit more in the bay tonight, but somethings haven't gone as planned and it's taking longer than it should which is a worry.
I went a bit mad on some shopping - best part of Ł100 on fluids and cheap running in spark plugs.
The Roose hoses turned up and together with a shiny stainless map sensor bracket have helped tidy up the bay. Got a lot more to do though, but it's all relatively simple bolting up and tightening up.
Rad and fans are in, turbo is on, power steering pump is in, a few hoses are in, some new sensors are connected. More work is needed on the turbo hanger and actuator bracket, plus the turbo water pipes need some TLC with a hammer or similar!
As Stu says, 9 sleeps to go!
Simon
Old 05-04-2006 | 01:01 AM
  #44
RSBen's Avatar
RSBen
Wow, respect
Hope you do it in time
Old 05-04-2006 | 07:28 AM
  #45
Sticky.'s Avatar
Sticky.
Old 05-04-2006 | 05:21 PM
  #46
foreigneRS's Avatar
foreigneRS
Testing the future
Hi Si.
Hopefully nothing too bad will happen when the powder coating gets hot. It could get smoky and smelly though, so I wouldn't fancy it, that's all I'm saying.
Very good effort, and I'm looking forward to seeing it at the 'ring.
Old 05-04-2006 | 11:03 PM
  #47
richm's Avatar
richm
Well...!!!
Somerset RSOC monthly meeting tonight, and that pile of parts in the pics so far now look like this.....
But.... it's never that easy is it....
i wasn't really listening to the details, so Si/Phil/Doug will have to fill in the commentary...
how many PF'ers can you spot under there then..
just as well make use of a bit of excess heat.. somebody missed their tea in the rush
Old 05-04-2006 | 11:09 PM
  #48
Si B's Avatar
Si B
Wednesday 5th April 2006 23:45
SHE RUNS!
Great news and a big relief for me - the pretty much brand new engine started first time, and has clocked up an impressive 45 miles, and one Fast Ford photo shoot.
Not bad considering a few days back all I had was a load of bits all over the house and garage!
It wasn't all plain sailing though
Basically the first problem was the smoke - not out of the exhaust, but off of the exhaust As expected the 'high temp' powder coating was not up to the challenge. It just crackled up, and flaked off Nevermind, was worth a shot.
Second problem, the rubber o-ring on the fuel reg going into the fuel rail decided it didn't want to play ball when I tried to drive off for a test run.
It split, fuel pissed out everywhere and the car stank of the fumes. This was fixed temporaily at the roadside using super glue (good stuff ) and a large rubber donut/ o-ring cut and bodged to suit! Still in there 40 miles later, but soon to be replaced by the right bit.
3rd problem - some of inlet manifold bolts vibrated loose - caused by me not doing them up - whoops. Easy mistake to make after like 2 million nuts and bolts had been done, but meant the car made NO boost, and misfired like a bitch! Easily fixed once we knew what was up.
Now did I do those con rod bolts up more than handtight?
Some pics below of the semi finished article below. Plans for the next few weeks include GT30/35, 1000cc injectors, poss new cams and some nitrous, all aeroquipped, and everything made in stainless steel from 2400 Motorsport (My sponsors pretty much!). For now, Greys and T34 at 28psi
The engine all in and running:
The 2400 Motorsport inlet plenum (in stainless steel so should be up to the boost!) with funky looking throttle bracket.
Plenum again, with their fuel rail cover fitted. Looks mega bling bling and covers the mess of wires and injectors etc etc.
2400 Motorsport turbo hanger - prototype model, but looks more than functional and bling for me
The thermostat - just one of the 40 or so bits I got powder coated - has tidied up the bay no end. Many thanks to AC Powder Coating in Yeovil.
Plans for tomorrow (or rather later today as it's now 12:10am Thursday!) include more running in miles and checking everything is as it should be.
Fingers crossed I may get to the Ring in it! Big big thank you to Phill
Thanks also to my brother (Sketch) and Doug Stirling for their help, and Rich M for his advice ref the block ball bearing!
Simon
Old 05-04-2006 | 11:14 PM
  #49
Si B's Avatar
Si B
Beat me to it Rich!
Thanks for the pics - saw someone snapping away but was too busy chasing the air leak squeal to notice who or to pose!
The pics Rich posted show me tightening the inlet manifold back up. The chicken pasty was my grub as the engine was first started just 20 mins before the Somerset RSOC meet and Fast Ford shoot was due to start... nothing like cutting it fine
Simon
Old 06-04-2006 | 07:13 AM
  #50
Sticky.'s Avatar
Sticky.
Nice one Si, Phil & all who helped
Now go get some milage on it
Old 06-04-2006 | 07:18 AM
  #51
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Well done
Old 06-04-2006 | 08:33 AM
  #52
rstoughy's Avatar
rstoughy
10 /10 for effort there M8 car looks brilliant and hope all goes well at the ring
Old 06-04-2006 | 08:36 AM
  #53
Lou Lou.'s Avatar
Lou Lou.
Woohoo top work look forward to seeing it at the ring
Old 07-04-2006 | 11:25 PM
  #54
Si B's Avatar
Si B
Saturday 8th April 00:40
Thanking u folks
Car is running really nicely at the mo - have now done 120 miles, and plan to 1000 over the next day or two to run it in nicely.
Have been shopping for more goodies - ordered Adjustable top mounts and a compression strut kit to play around with the roll and camber/ caster gubbins
Hoping to get these fitted before the Ring, as long as I can find someone to set it all up for me.
Really starting to look forward to thursday, instead of dreading it
Anyone got some adjustable TCAs they want to sell me?
Simon
Old 07-04-2006 | 11:30 PM
  #55
Sean_RS's Avatar
Sean_RS
Old 07-04-2006 | 11:36 PM
  #56
Greg Shepherd's Avatar
Greg Shepherd
Chasing Radders
good work m8 enjoy the ring
Old 08-04-2006 | 11:13 AM
  #57
phill2400's Avatar
phill2400
I think somebody has switched the light on at the end of the tunnel.
Old 08-04-2006 | 11:21 AM
  #58
foreigneRS's Avatar
foreigneRS
Testing the future
won't have time to get mine run in and oil changed before setting off for the 'ring. will do it when i get there
Old 08-04-2006 | 11:54 AM
  #59
CliffRS4's Avatar
CliffRS4
Such amazing work in so little time
Old 08-04-2006 | 12:16 PM
  #60
Stu @ M Developments's Avatar
PassionFords Creator
Top Work
Old 08-04-2006 | 12:28 PM
  #61
Paul Eggleton's Avatar
Paul Eggleton
10 out of 10 for effort Hope you now have a fun and trouble free trip
Old 08-04-2006 | 04:53 PM
  #62
toff's Avatar
toff
top work boys
Old 08-04-2006 | 06:18 PM
  #63
Sketch's Avatar
Sketch
Im still gonna whoop him with the 205 though Toff
Old 08-04-2006 | 10:44 PM
  #64
Si B's Avatar
Si B
Yeah sure you are! Bring it on...
Truth is, I'll prob be taking my Mi16 205 as well.... unless I'm blessed with luck I don't usually have!
Old 09-04-2006 | 08:09 AM
  #65
puddy's Avatar
puddy
Very well done
puddy
Old 09-04-2006 | 07:40 PM
  #66
Si B's Avatar
Si B
Sunday 5th April 2006 20:39
Turbo's dead
While running in at a heady 10psi the T34 has decided to join in the fun inside the engine rather than stay on the outside of the engine
I've done 750 miles of running in since 11pm last night, had just 250 to go when it all came to a halt...
Update & pics to follow
Old 09-04-2006 | 07:44 PM
  #67
Rick's Avatar
Rick
Shit news!
What's it done? Something broken, or just oil seal?
Old 09-04-2006 | 07:45 PM
  #68
Daviet's Avatar
Daviet
had just been reading this thinking all was going ok
hopefuly you get it sorted mate
Old 09-04-2006 | 07:52 PM
  #69
Old 09-04-2006 | 08:00 PM
  #70
Sticky.'s Avatar
Sticky.
Sorry to hear that Si
Hope you get it sorted before Thursday.
Old 09-04-2006 | 08:02 PM
  #71
The Youth.'s Avatar
The Youth.
no doubt you will be able to fix it in time, at the rate you work the turbo will be off allready!!
good luck anyway
steve
Old 09-04-2006 | 08:10 PM
  #72
AlexF's Avatar
AlexF
Can you sort it?
Alex
Old 09-04-2006 | 08:23 PM
  #73
Eagle's Avatar
Eagle
Super Moderator
foook .. sorry to hear it mate ...
Old 09-04-2006 | 08:41 PM
  #74
NUTS RuS's Avatar
NUTS RuS
Old 09-04-2006 | 08:55 PM
  #75
Sketch's Avatar
Sketch
Shit news indeed......
Think he'll need to borrow a turbo and fast Wonder he has got a spare T34 .55 / .63 kicking about?
***UPDATE***
He's just been round to mine and picked up my T34 which has just been re-built by Danny @ RADesigns!
Should be fitted by his usual midnight update time
Old 09-04-2006 | 09:09 PM
  #76
Sticky.'s Avatar
Sticky.
Old 09-04-2006 | 09:20 PM
  #77
Grahamxx's Avatar
Grahamxx
Originally Posted by Sketch
***UPDATE***
Now that’s brotherly love for you.
Keep the good work up Simon
Old 09-04-2006 | 09:26 PM
  #78
Si B's Avatar
Si B
Sunday 9th April 2006 22:11
Set off last night on a 750 mile running in road trip, got to within 15 miles of home, and noticed a total lack of go - could only make 5psi (had been running 15 psi most of the time). Backed off and saw a load of blue smoke, and thought f@#K it!
Been here before
Limped the car home, smoked out my neighbours, and here is the end product:
Pics:
Took air filter hose off:
Took turbo off and apart:
Engine as it is at this mo:
Big up me little bro SKETCH - lent me his T34.63! Thanks bruv
Like a lamb to the slaughter - the T34 on my bench waiting to go meet it's maker!
Big up to CHIP who has also offered to lend me his newly refurbished T34 as a spare for the Ring trip - PassionFord goodwill coming to the fore as usual
Going to put Danny@RADesigns seals to the ultimate test seeing as he has resealed both of these Turbos!
More pics as the new turbo goes on (tonight!!!)
Anyone got a nice T34 .55 or .63 they want to sell me? Will browse ebay shortly...
Simon
Old 09-04-2006 | 09:35 PM
  #79
bud-weis's Avatar
bud-weis
Football Cwazy
so where did all of the broken pieces end up
hope you get it sorted
Old 09-04-2006 | 09:39 PM
  #80
Si B's Avatar
Si B
Good question....
Bigger bits are stuck in the intercooler end tank, smaller bits have gone to see what all the fuss is about inside the new block
bastid cars!
Quick Reply: WE'RE ON THE WAY!! Ring Countdown - NO Days to Go!!!
