First niggly problem...HELP
Old Mar 27, 2006 | 04:03 PM
Default First niggly problem...HELP
....now at 6k revs on any boost i hit like a rev limiter...it goes bang bang...now the limter hard cut is set to 8200rpm so i cant be that...unless my rev counter is out?...Only thing i have tried is closing the spark plug gap to 0.5mm...and no difference...everything else is new...i think it only does it after its got fully fully warmed..not sure though cant remember What van it be?...i must admit i am using old std ford leads and i mean old...trying a set of 909 leads tommorrow...could a plug be down...they are new?
Old Mar 27, 2006 | 04:12 PM
Disabled Account's Avatar
Disabled Account
Overboosting - ECU boost cut Phil..............
Rick's Avatar
Rick
can u drive through it off boost?
Old Mar 27, 2006 | 04:15 PM
Doug no it does it at 25psi too and karl said no probs to 35psi peak!
Rick i have not tried
The only other thing i have done temporaraly is put a bleed valve in the actuator to amal line...would that effect the ECU to throw its dummy?
RS Grant
16
Mar 10, 2014 11:16 PM
LUKEY1992
Fiesta's Other !
Dec 30, 2013 02:00 PM
Matt Evans
Aug 22, 2013 10:08 PM
DavebST170
Jun 22, 2013 09:01 PM
