Big Brake advice needed
I have just bought a set of AP 6 pot 378mm brakes, and was wondering if my 300mm rear discs would be sufficient to use with it? I was worried there would be too much braking force on the front?
Thanks
Thanks
Thanks, just in a dilemma as to whether to put my current AP 4pot 330 on the back or to sell them Just dont want my car dipping too much on the front and destroying my lovely CF splitter
i have AP 6 pots with 355 mm discs.
i removed the bias valve to try and get the rears to work a bit harder.
they are amazing but could be improved upon by fitting some larger rear brakes.
best way to test your set up is disconnect ABS and brake hard(be careful)
the fronts should lock a fraction before the rears.
i know mines needs bigger rears cos i cant lock the back at all.
track.focus'd
12-08-2015 05:53 PM
Jack and the Beanstalk
09-08-2015 07:03 PM
