Wire rung 200 block?
If a YB 200 block has been wire rung/ringed (whatever lol) does this mean the wire needs replacing everytime the head has to come off? Also do you use a standard head gasket??
Cheers Spadge...
Cheers Spadge...
Originally Posted by Stu @ M Developments
Any fibrous gasket with a soft metal fire ring is fine
Wire, if correctly installed, will also be fine. Just check its still rounded and not crushed flat anywhere.
Cheers for the reply Stu i was kind of hoping you or Karl might reply!
Can you just look at the pics below and tell me if the pistons look like standard 4x4 ones and what the numbers mean on the top?
Cheers Spadge...
![](https://img.photobucket.com/albums/0603/spadge/37e12e8d.jpg)
![](https://img.photobucket.com/albums/0603/spadge/45658985.jpg)
standard pistons and the numbers are the size of the piston widths,so you can tell if its has been oversized.
what size is standard and what is oversize. ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I don't actually thing the 91.275 number is the size though i suspect it is a Mahle part number?
Originally Posted by GUZZLER
.5mm oversized.
Does that mean a standard on is 90.775 then or is that number fook all to do with the size????
Cheers mate
there the sizes Jules, the 'sp.50' or .05' bit is bore clearance.
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Guzzler
Cheers mate you have saved me no end of grief as the other block and pistons i have on Ebay are 1mm over and not 0.5 that i thought
Thanks for the info pal!
Spadge...
Spadge...
