My engine problem.......
Old Mar 21, 2006 | 03:40 PM
Default My engine problem.......
...some of you may remember i had a problem with my fuel pressure gauge...it came out of a working car and then was put in my Saff and it showed a problem....maybe i had wired it up wrong which was feasable and blew it....but it always went to 0 on ignition and when priming went to the right fuel pressure...except on boost it stayed static.....
I have put a new regulator on it which is maybe unheard of being faulty...but it all leads to that
1...The fuel pressure gauge shows no rise on boost
2...The fueling according to LM1 on a T4 chip and a GT35 chip shows at 22psi it is leaning off as the revs rise,upto 13.5afr
3...You pull the vacuum pipe off at idle and no change in engine note
4...I put 30psi via a foot pump into the reg at idle and the LM1 never changed AFR...car didnt even make any changes in note...
Lamda is in downpipe just from the turbo so accurate.
Fucked regulator? Imagine now when YOU put an off the shelf chip in and you dont know what your fuellings doin,maybe...KABOOOOOOOM...A very big specced engine could have been melted if i hadnt had the right equipment...as the car runs SPOT ON so no way an average person would know!!!
Old Mar 21, 2006 | 04:36 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: My engine problem.......
"IF" that is correct, the problem is the pipe. Its Blocked. But... i presume you actually meant no change in AFR.
Old Mar 21, 2006 | 04:42 PM
Stu on the escos if you pull that pipe off the note of the engine changes...it revs slightly higher ...but aside from that it isnt blocked for sure..checked all that
Old Mar 21, 2006 | 04:45 PM
Make your mind up, it either changes slightly cos it speeds up, or id doesnt change.. which is it?
Old Mar 21, 2006 | 04:47 PM
Stu....the SAFF'S note does not change pipe on or off
Escos revs slightly higher on pulling pipe off
Old Mar 21, 2006 | 04:49 PM
That means one of 4 things then top of my head.
Pipe is blocked.
Regulator leaks to atmosphere.
Idle speed is VERY high already.
Idle content is so rich the extra air didnt allow the engine speed to increase.
Old Mar 21, 2006 | 04:54 PM
....regulator deffo fooked...in my opinion i can do no more tests...i had fuelling for 700bhp on a gt35 1.06 housing map and the AFR read 13.8 at 8K it got leaner and leaner as the revs rose...unless my t4 is actually a gt42
Old Mar 21, 2006 | 04:57 PM
Soon find out mate, new one with you by 1pm tomorrow at latest.
Im just confused as you once said it held the 30psi... thus must be airtight, yet when you pull pipe off, no airleak at plenum!!
Pipe is blocked.
1...Will check again before fitting new one.
2...Hold pressure from foot pump
3...Idle speed 800rpm
4...around 6% co at idle at the mo...need to trim that
Old Mar 21, 2006 | 05:00 PM
....Stu you are right...i just thought no vacuum leak ...But it still didnt move AFR with 30psi in the reg...so if the pipe was blocked the 30psi would for sure have flooded the engine....
Old Mar 21, 2006 | 05:05 PM
...infact the CO at present looking at conversions is around 8.6% that may explain no rise in revs!
Old Mar 21, 2006 | 07:09 PM
You got a huge plenum fitted? Maybe the cam timing / plenum combination is creating very little depression in the plenum.
Old Mar 21, 2006 | 09:24 PM
Billabong's Avatar
Billabong
He's got the 10mm plenum spacer fitted, would this make enough difference to his diagnostics - I guess theory says if it makes a difference to the potential of the power etc. then it could do?
Old Mar 21, 2006 | 09:49 PM
No, i certainly doubt the spacer alone would drop the gas speed to this level. One i built recently uses a 14mm one with a pair of BD14s and Karls biggest head and that still pulls 15inhg at idle no problem.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
