Closed loop MOT question
Old Mar 17, 2006 | 02:13 PM
B11GNS's Avatar
B11GNS
Default Closed loop MOT question
My car reads 0.6% on the emission test because of the closed loop lambda set up and they test the car on idle. But i was wandering as to be in lambda mapping the ecu must sense, a) boost is below 4 psi, b) less then 60% throttle, etc, etc, and also when the engine coolant is above 70 degrees, so what i want to know is what happens if the car is tested when its cold, i.e you leave it with them all day and they test it later on, would it then fail the MOT as it isn't meeting the needs for lambda hence will be in normal cosworth mapping?
Old Mar 17, 2006 | 02:14 PM
Jim Galbally's Avatar
Jim Galbally
they dont test it cold for an MOT. its in the regs
Old Mar 17, 2006 | 02:16 PM
richm's Avatar
richm
same problem with any car - they 'should' always be testing with a warm engine to perform the test correctly. A catalyst will not be working unless it (and the engine) is hot.
Old Mar 17, 2006 | 03:09 PM
B11GNS's Avatar
B11GNS
Hairy muff! cheers guys
Old Mar 17, 2006 | 04:08 PM
Rick's Avatar
Rick
As above - always warm
Old Mar 17, 2006 | 04:28 PM
AndyBlackFRST's Avatar
AndyBlackFRST
MOT won't be able to start as equiptment will be used to check oil temps
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
