Changing valve stem oil seals on a cossie?
Hi all
What is the correct procedure for changing the valve stem oil seals on a YB engine please?
Cheers Spadge...
Cheers Spadge...
pull of the seals and re fit the new ones with a socket that fits just around the metal rim of the steam seal tap it on. you may need to use a extention bar as a cossy head is a littel deep but make sure the valve guides are clean .the old seal could be hard to remove some time but if you have a steam seal puller it wount be to hard after fitting them make sure no seals have ripped when fitting them
chances are they will be F.tight spadge, without the proper puller it may well be all but impossible to pull them off - you may well have to split the metal down the side of the seal with a sharp screwdriver and gentle hammer, they will fall off then
Testing the future
you need 2 different sized sockets ideally, as the inlet and exhaust valves have different thickness stems.
before all of that of course, you have to remove the valve springs. so you need to hold the valves closed. easiest by removing head, or supposedly possible with head still on using compressed air or rope fed through spark plug hole.
I just done them, need the head off, cams out, hydraulic lifters out, valves out then you can get at them.
As above they are really tight, i couldnt get them off even with the proper tool which grips there outter edge . . . . so i chiseled (with a normal flat blade screw driver) the metal outter casing, then they just fall off.
The new ones sit nicley inside a 10mm or 11mm socket and can be gently tapped on.
Good luck mate
Good luck mate
No probs mr cossie604
They are a bit of a bugger aint they!
I found with the proper tool to get them out i slightly scratched where the hydraulic lifter sits and it was hard to get the lifter back in, so i gave up and chiseled with a screw driver
As above with a gentle tap and screw driver.
Re-fitting the collets was the worst bit for me though. Done loads of them over the years and still dread that bit. One of that jobs where you JUST have to be in the mood.
Originally Posted by cossie604
Done mine, as above they are a real tight fit. I also gave up with thte correct tool and ended up useing a pair of snap on long nose pliers that have a ring grip on the end...still took ages and a lot of swearing and cut finger
Stu
Stu
you need to be more phil than del
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
st220kyle
16
14-08-2015 06:13 AM
rsstav
11-08-2015 04:22 AM
