BODYWORK SPRAY MATCHING?????
Ive got a s2erst in diamond white and im needing the drivers door spraying would it be possible to just spray the door or would the whole side need spraying to match, btw the cars diamond white
happy with that
if there good enough you can usually get away with just spraying the door,its a flat coulour wont need blending,we do it at work,even with some metalic colours
JezSierra
Whatever you say mate... at your "work" you often paint 15yr old Diamond white escprts do you? You realise there are numerous variants of this colour dont you..??
focus rs 1672
Originally Posted by Damo V
JezSierra
if its a new car would be easy but not a old car,might even need full side done dependin on how faded paint is
how would you blend it into the wing, w/o making the wing look shite? i can paint a panel ok, and make it look good, but i wouldnt know where to start without painting the whole panel.
key up the panel(s) to be blended, use a basecoat, effectively flicking it across ajoining panel, then clear coat over the whole lot, have you used base and clear before?
yup, on an xr2... only prob was, as i have no booth and it was summer, i kept on getting flies under the clear
so does the clear coat stop the blend from being visable?
i need to spray my radient red o/s door soon, so...
JezSierra
when i took my car for a quote for one of the arches to be done (radiant red s2) I was told they would have to blend it into the door.
they do all the main repairs for Merc, so I trust they know what they are on about
I seem to remember being told there was eight different shades of Ford Diamond White.
I've had my front bumper done once, and they managed to get a very good match, but not so certain it would be as good on the side of a car.........Would recommend taking a good body shop's advice on this one.
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
