400bhp
hi all i am thinking of going to 400bhp with my 2wd saff, but am not sure what i need to do. my car is currently 341bhpspec as follows;-
wire rung 200 block
mahle low comp pistons
grp a headgasket
t34 with 63 housing
- 31 actuater
greens
rs 500 intercooler
3 bar map sensor
standard air box with pipercross panel filter
l6 ecu with bayoo chip
any help much appreciated.
thanks danny
wire rung 200 block
grp a headgasket
t34 with 63 housing
- 31 actuater
greens
rs 500 intercooler
3 bar map sensor
thanks danny
change the head gasket, as its not the best for a wire rung block
depends on the compression of your engine, grays and a remap, and you wouldnt be far off 400BHP
it will be fine if the wire ringing is done right
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Injectors and a map and there is absolutly no reason why you cant have over 400bhp,
Only suggestion i'd make is to get a 360deg bearing in your turbo
TiB
because he uses the Group A gasket and not the the standard gasket,, not the fact thats its wire rung,,, infact i like wireringing
Bosch-Man
compression is EVERYTHING
if its 7:9:1 i dont think he'll get 400 bhp on a t34
Bosch-Man
Originally Posted by B11GNS
As said, greys, and a live map should get you close. Mine ain't far off 400 and thats on standard comp!
Originally Posted by cossiedrift
can i have my l6 live mapped or what? how much for greys or light blues? will i need cams or not?
you wont really need cams with a standard spec head
Originally Posted by Bosch-Man
Garerth why the compression comment?
At a guess because high compression is going to mean masses of ignition retard to use big boost, which is going to lessen the power potential slightly.
And 400bhp on a T34 is a tall order to start with!
TiB
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
sounds good i have been fed a load of bull s#i# saying i need cams l8 4wd position sensor and loads of other bits. how much would live map cost and who would you reccomend? thanks danny
MPG depends on how you drive really but i get more to a tank now then i did with standard yellows!! And the emissions are at about 0.6 %!!!!!
I now have a L8 ecu as you need that to run the closed loop, HTH.
Not a problem i encountered, never even heard that before???
![](https://passionford.com/forum/images/smilies/smile092.gif)
![](https://passionford.com/forum/images/smilies/smile073.gif)
if your buying a L8 ecu, it must have the ford standard baby board inside
You will need the ecu and a 4x4 tps, which stu supplied me as well as the lambda and software
Originally Posted by Rhys
I though head porting and cams or (cam)
is a must for 400bhp?
you can get very very close without them
any idear what to expect to pay for an l8 ecu?
