massive overboost promlem :(
Old Jul 28, 2004 | 10:37 AM
darren.cudd's Avatar
darren.cudd
Default massive overboost promlem :(
first of all, sorry for posting in the wrong section stu, pet ect but kinda need a quick answer as per usual
mates car (cossie kit car) is ment to be running the normal 1.6 bar boost.
problem is were getting massive spikes of over 2 bar before it holds at 1.4 ish
he did have a -34 actuator on it but now has a -31 and its made no difference!
anyone got any ideas?
its running a t34.48 if that makes a difference.
PLEASE HELLLLLLLLLLLLLLLLLLLLLLLLLLLLP
Old Jul 28, 2004 | 10:39 AM
Rene's Avatar
Rene
u using the amal valve?
maybe a boost/hose leak somewhere ?
Old Jul 28, 2004 | 10:48 AM
darren.cudd
no amal valve, he has a bleed valve fitted so he can fine tune the boost level but dont think its got anything to do with that as we tried 3 in total and it still does it
pretty sure there are no air leaks but it could be that i supose thing is, would an air leak in one of the hoses cause that amount of overboost? its shutting down everything as soon as you plant it
Old Jul 28, 2004 | 10:51 AM
Stu @ M Developments's Avatar
PassionFords Creator
Wastegates sticking or leak in signal to actuator.
Old Jul 28, 2004 | 10:53 AM
Jim Galbally's Avatar
Jim Galbally
how long is the pipework before the actuator?
if its REALLY long then this will cause it, as it takes a while for the hose to pressurise so the actuator lags behind...
this can be nasty on unlaggy turbos like wwin T2s as the fookers will spike at about 3times what they should hold
Old Jul 28, 2004 | 10:54 AM
darren.cudd
ok cheers guys, will check the boost hoses
stu, you could be right acually as he snaped the wastegate arm a little while back and had to weld it back together i guess he may have done somthing to make it stick then
anyway thanks
Old Jul 28, 2004 | 10:57 AM
Well.. is that when the problem started or not?
Old Jul 28, 2004 | 11:02 AM
darren.cudd
not sure mate will have to ask him probably is that though as he braced it up with webbing like fook so it wouldnt break again
bit obvious no that youve said it but you know how it is when your trying to think of a problem and just keep looking at the same thing
thanks
Old Jul 28, 2004 | 11:18 AM
Originally Posted by darren.cudd
bit obvious no that youve said it but you know how it is when your thick as pigshit and damaged it yourself...
thanks
Nope.. cant say i do actually.
Joke...
Old Jul 28, 2004 | 11:20 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
thanks
Joke...
LOL
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
DixieTheKid
Sep 14, 2015 09:04 PM
