Next update....
Old Mar 8, 2006 | 05:40 PM
Default Next update....
All seems ok mechanically apart from the fuel pressure gauge or reg situation....The car feels lovely boosted her up to 5psi to 4000rpm and it felt quick ...The 7.9-1 comp ratio is nice for guts below boost ....Had a fit today in traffic though..saw 200f on the water temp gauge and i couldnt work out how hot that was as i am used to centigrade not fareheit ....I thought has my head gasket gone?LOL....As soon as i was moving temp went back down...phew....So i got home and left it running and running till the fams came on...they do so at 205f...what is that in proper money?...Temp goes down nicely...Cossie paranoia.. ...Only other issue is the fooking clutch...6 paddle job and it bites really low and is horrible...nothing like in my other saf with the same... Was told to use the Escos rachet setup....but i have a feeling the original cable is stretched...feasable?????Will try new cable first...still drives nice but is difficult pulling away especially on a hill!
Old Mar 8, 2006 | 05:42 PM
bud-weis's Avatar
bud-weis
Football Cwazy
boiling point for water is 100C, so i'd say your readings are either very wrong, or very worrying!!
Old Mar 8, 2006 | 05:44 PM
...read it again mate
Old Mar 8, 2006 | 05:45 PM
trevCOSS's Avatar
trevCOSS
but as stated he said it was reading degrees fahrenheit not celsius boiling point of water is 100 degrees celsius
Old Mar 8, 2006 | 05:46 PM
Disabled Account's Avatar
Disabled Account
Default Re: Next update....
Originally Posted by Bosch-Man
till the fams came on...they do so at 205f...what is that in proper money?...Temp goes down nicely...............
205F = 96°C
haz87's Avatar
haz87
For all your temp info:
http://shopswarf.orcon.net.nz/centigrade.html
bud-weis's Avatar
bud-weis
Football Cwazy
good lad,nice edit
bout 96c then, which is good i reckon
trevCOSS's Avatar
trevCOSS
http://www.onlineconversion.com/temperature.htm
Old Mar 8, 2006 | 06:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Good luck with your car
Been nice to see you being pleasent to others for a change
Steve.
Old Mar 8, 2006 | 06:39 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
phil you should receive 1st thing in the morn
Keep the updates coming
TimWeeble
287
Aug 11, 2022 02:40 PM
lawnsy
27
Apr 6, 2009 08:12 AM
Xindi
Ford Classics & Vintage
May 17, 2008 07:09 AM
