2wd plenum vs 4x4 plenum.....
Old Mar 6, 2006 | 05:51 PM
CosKev3's Avatar
CosKev3
Default 2wd plenum vs 4x4 plenum.....
Is there any gain from changing the 2wd plenum/elbow over to a 4x4 plenum?
Have read on here before that the elbow on the 2wd is restrictive.
Car is going to be live mapped on greys in April,running T34.63,just wondered if it is worth changing the plenum or is the 2wd plenum/elbow ok for this power level?
Thanks
Old Mar 6, 2006 | 06:28 PM
The problem with the 2wd and 4x4 is the distance between trumpets and cover...solution is put a 10mm spacer on.
Old Mar 6, 2006 | 06:30 PM
rapidcossie's Avatar
rapidcossie
or get a eecv plenum and throttle as its bigger than 4x4 and 2wd
Old Mar 6, 2006 | 06:33 PM
CosKev3's Avatar
CosKev3
Got a spacer to fit
Any gain to be got for changing the plenum do you know,or just use the spacer and 2wd plenum???????
Old Mar 6, 2006 | 06:49 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Changed mine from a 2wd to the 4x4 and got a 8bhp gain with the same boost
Steve.
Old Mar 6, 2006 | 09:02 PM
CosKev3's Avatar
CosKev3
Steve.
Nice one
What did you do with the fuel rail,I noticed the one mounting point is different?
Old Mar 6, 2006 | 09:04 PM
abdr500's Avatar
abdr500
CosKev3
you use a 4wd fuel rail i have one £10 if any one wants it
Old Mar 6, 2006 | 09:13 PM
CosKev3's Avatar
CosKev3
Originally Posted by abdr500
CosKev3
Will need a different fuel regulator then too???
Old Mar 6, 2006 | 09:42 PM
900ss's Avatar
900ss
RWD Racer
yep
mark r
Sep 29, 2015 07:27 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
rog
Sep 16, 2015 03:00 PM
