**Brrrrrr its cold need HELP !! *Updated* **
My fan has stopped working for my heater in my car need some ideas on what i can check please??
Have still got heat just nothing to blow it out to warm me up
couldnt even clear my windscreen this morning
looks like you're going to have to drive with your nipples
Thanks Stu will have a look tonight
Will check to see if it might be a fuse aswell Rich
and i normally have a scarf and hat on anyway
Fpmsl @ Dave
![Content](https://passionford.com/forum/images/smilies/content.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Fpmsl @ Dave
Originally Posted by Mr S1
If you've got heat then I doubt it will be anything electrical (?) more a way of getting it into the cabin..............
I would say its the blower itself (normally under the glove box but not sure on an RST) or power to it i.e fuse
Don't ask - I don't know
pmsl so you reckon a fuse then ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I would say try the fuse then switch then try the blower
The heater fan is in engine bay on them isnt it? well i know it is on ERST and is piss easy to remove. Check fuse first if not whip the blower out and pass a current through it to see if its knackered!
Hey Lou - Billy here lol
I know what it was............ You never had "The Glove" on
I recon switch, as i'm sure there'd be a few other things not working as well..... IIRC its only the overheating fan that has its own fuse on the heating system. I'm sure the heater blower shares a fuse with some other bits................
But then i could be wrong
Originally Posted by DUDE_SWEET_FRST
everything else working ok?
Pmsl cheers Paul see its my own fault for not taking your gloves
i cant remember if the blowers are fused with anything else or not
I hate to sound stupid here but if your blower isnt working how do you know you have heat?
On my escort gti i have absolutly no air at all unless i switch the blower on.
Because when your driving along you tend to get a certain amount of heat through and even tho the blower wasnt working when i put my hand infront of the vent last night it was hot
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Hmm well mine was working fine yest morn but last night when i was freezing cold and needing warming up it decided to not play ball
Not had any probs before with it
Update
I checked a few things out last night and i discovered that my reverse light doesnt work either which is on the same fuse as my heater fan, the fuse looked fine but changed it over anyway and still nothing
Any more ideas or any suggestions of someone local to me that can help me out please
Could be an earthing fault of some description.
Also, take the fuse out, and check inside the actual fuse holder to see if's corroded at all.
Could also check with a multimeter that you're getting power both sides of the fuse.....
It didnt look too corroded when i had a look last night but it was getting dark so will have a better look at the wkend and will check with the mulitmeter cheers Rich
Well Dal said last night it could be the fuse box is this an expensive thing to sort out?? any ideas who could do it for me?
could also try the basildon ford spares place on the burnt mills estate.. their wicked for new parts cheap
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
If that is the case then
How can i confirm it is this thats fooked tho? is it a case of if the multimeter says that im not getting power to both sides of the fuse? or is there anything else to check
