Tiff's 205 MI-16 was the fastest at Bedford! Sketch 2nd.....
#42
Well....
Im 99% sure Tiff runs the mi16 box....
I run the 1.6 box
SiB runs the 1.9 box (although i believe he is changing it for 1.6 today if all goes to plan)
I run the 1.6 box
#44
Originally Posted by ballin
i thought tiff's was a 1.9 with played with ratios
Originally Posted by Tiff
It has Mi16 gearbox/clutch with longer specced gear ratio's
#45
Originally Posted by Karl
The box is a mix of ratios, but is in fact perfect for the engine!! Id rather not say what the ratios are else everyone else will do the same!! It maxes out at 147mph at the limiter in 5th which is 7600rpm. Any shorter than this would be painfull on the road as at under 20mph per 1000 in 5th its short enough!
The car does:
45mph in 1st, 68mph in 2nd, 92 mph in 3rd, 118 in 4th, 147 in 5th.
The car does:
There we have it.....
#46
Chasing Radders
The car does:
The car does:
Everyone know knows which corners to get me on
#47
TIFF Any ideas how much a similar if not the same conversion your car has would cost me if I sourced the engine etc myself? I'm looking at buying a 205 at the moment and would like to get it specced up similar to yours.
Stu
Stu
#49
Originally Posted by TIFF
Stu
You would be better off asking Karl as he built the engine that is in it before i bought it
#51
2Evos & 1 Escort Van :-)
Cool, the challenge is on!
Or not in my case
A) I haven't had time to do the gear box, so no lower ratio 1.6 box for me. So may be ok on the long straights, crap everywhere else.
B) Sketch's (my bruv) car goes better than mine (may be the gear box, but think the engine is sweeter than mine as well)
C) While Sketch has done 1000+ miles I have done 100
And in the first 20 miles I broke the accelerator cable
(fixed very kindly by Phill2400 from 2400 Motorsport )
I've also broken a TCA
I've also buggered the indicators
Fixed one oil leak, only to find 3 more to sort by Sat
The comments above about me driving it like it's stolen I deny strongly, even though it's true hence all of the above points!
Tony The camera comment was just plain nasty! Bring on your r(over)s1600i is all I have to say! (Another car to overtake me )
So basically I'm screwed
See you all there, I'll be the one pushing my Pug around the pits!
Simon
Or not in my case
Simon
#52
How the fuck did you bugger the indicators? Was it straight 50, into rough and bumps 20, over bridge into water splash? Might explain the buggered TCA
#53
1st = forgot to do
2nd = about 70mph on the clock
3rd = about 95mph on the clock
4th = dunno
5th = Approx 145mph at 7250rpm (not sure what my limiter is set at, 7250ish i think!
So the ratio's look similar ish, I dont think my 1st will do 45mph though
#59
Originally Posted by Doug Stirling
Originally Posted by MJC
..........what does Karl have now then?
#60
Originally Posted by Shings
Only because as standard it lasted less than a week PMSL poor peugeots.. made from monkey metal
#61
#64
Originally Posted by keithG666
would have been in an MI16 if my two financial partners hadn't of 'bailed' on me!!!!
YOU KNOW WHO YOU ARE!!!
#71
Wellllllllll
we only really got to go out and play with Nige once on the last session when we had fucked the slicks well and truly...
Sketch decided to literally cut sections of the track out to get in front....
But still didn't
But still didn't
#73
Well, Put it this way...
Sketch thought that by cutting the corners he would beat me
Had a good 6 laps going against Sketch and i think he has it on film too
#74
Chasing Radders
Wellllllllll
#80
Chasing Radders
Originally Posted by stew205
Looks to be a top day then as i havent gone up against another Mi16 205 yet......so will be fun
Sounds like it was a good day
Was a VERY good day today
