rst conversion?
Old Feb 20, 2006 | 10:18 PM
rst in breaking's Avatar
rst in breaking
Default rst conversion?
i have a 1.4 escort van that in looking to convert to an efi rst, what parts would i need that i can get of my friends mfi cabriolet rs he's breaking, i already have the engine, could i keep my tank (its petrol) or would i need an rs tank? fuel lines etc? cheers
Old Feb 20, 2006 | 10:39 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
the tank will need a return i think....
Then everything off an FRST, loom, ecu, sensors, injectors etc etc
Post up in the FRST room and ask
Old Feb 20, 2006 | 11:47 PM
andyhardy's Avatar
andyhardy
You could get most of the stuff off an EFI 1.6 CVH Escort or Fiesta, not just a FRST.
Fuel rail, inlet manifold, injectors, cylinder head are all the same for a start as well as the loom itself which will plug straight into the ECU with just a simple change of the wiring.
You'll also need an EFI flywheel and if using an MFi bottom end you'll need to get a CPS hole tapped into the block as I believe the MFi bottom ends don't have this.
There's a guide on what would need changing on the loom side of things here... (2i loom is the same as EFI 1.6CVH Escorts or Orions)
http://www.fiestaturbo.com/forums/viewtopic.php?t=77331
I think you'll have to rethink the tank a bit though like has been said above.
Cheers,
Andy
Old Feb 21, 2006 | 09:41 PM
rst in breaking
im running efi and ilbe getting an xr3i loom and modifying that but wanted to know if id need the fuel pump? and would the rst tank fit the van? would i need the fuel lines to?
Old Feb 21, 2006 | 09:43 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Best to get the tank as the RS has an anti-surge inside
Old Feb 22, 2006 | 09:35 PM
rst in breaking
cheers mate
mk3ste
Oct 17, 2021 10:09 AM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
