2wd coilover question
adjusted the ride height to where i want it and when the the car gets jacked up thers a 2" gap in spring to damper,is this right
they are tarmac spec 909 billys if that helps
the spring is 14"but dont know the rating
You mean at full droop the spring leaves the top cap ?
Yes thats normal , you can get a Helper spring that keeps the tension , stops the top cap from dropping out and misaligning with the spring top .
Originally Posted by Jim Galbally
it's an MOT failure for one
if its doing that then you've bought the wrong springs for your spec
why when do they jack the car up for an mot ? it goes up on a ramp ?
Stu (your friendly MOT tester for the passed 6yr)
Here's another 1 for you...are cut road springs a MOT failure???
Answers on a post card ppl lol
dojj
28
11-09-2015 10:00 PM
andrewmctiernan
08-09-2015 03:05 PM
