Removing a 4 door cossie (2wd) front bumper and rear spoiler?
Old 03-12-2016, 08:30 AM
Wessa
Wessa's Avatar
Location: An Essex lad now in Christchurch, New Zealand.
Default Removing a 4 door cossie (2wd) front bumper and rear spoiler?
Hi Fellas,
Im struggling to see how i remove the bolts/screws from the rear spoiler and also how to remove the front bumper from its mounts..
Any tips ?
Thanks in advance
Old 03-12-2016, 08:47 AM
155lee
155lee's Avatar
What's the problem,are the bolts seized?
The rear spoiler has2 Allen headed bolts under the 2 small caps,if they are seized you would prob be best drilling them out,then remove the boot lock and the steel plate and there's 2 bolts under there.
Front bumper fixes through the wings just in front of the wheels,the captive nuts usually spin so what I have done before is pull the bumper out and get a hacksaw blade between the bumper mount and wing and cut the bolt.
Then undo the foglight connections and the bumper simply pulls forward.
The old captive nuts can be tapped out and new nuts fitted with some araldite.
Hope that helps
Old 05-12-2016, 07:54 PM
Wessa
Wessa's Avatar
Hope that helps
Thanks for your help Lee,
The front bumper is off ok but the spoiler bolts are all seized
Cheers mate.
Old 05-12-2016, 08:26 PM
155lee
155lee's Avatar
No bother,i removed mine a couple of weeks back so knew how they should come off.
In the bootlid there's captive nuts,if you drill down you should only drill the bolt out and be able to sort out the nuts once the spoiler is off.
Old 06-12-2016, 05:15 AM
jdsjojo
jdsjojo's Avatar
Did you need to take the front wheels off to get at the nuts in the wings? What do you do pull the arch liners back? Cheers
Old 06-12-2016, 08:49 AM
Wessa
Wessa's Avatar
Yeah, there is one screw in the plastic arch. Unscrew that then you will see the bolt head or screw holding the side of the bumper on. Its really simple once you know how.
