Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
mk4 1.6 efi running issue
Old Nov 2, 2012 | 06:57 PM
suffolk04's Avatar
suffolk04
Default mk4 1.6 efi running issue
New to the site, can't believe i didnt join sooner, seems to have every classic ford covered, so hopefully someone can help me, because i'm at the point where im thinking about trading my car in and buying a new one.
anyways, it the mk4 1990 efi with iscv on the inlet manifold, i've fitted a recon engine, so swapped all the working parts from my old engine over, tps,iscv,map etc except crank sensor. The car cuts out when braking, and idles horrible, done ecu re-learn, base idle setting, checked for leaks with brake cleaner but no better.
if i disconnect tps, the revs pick up a little, but idles better, replaced it, still the same.
Also the emission are better with the tps disconnected.
Co-2.66
co2-10.00
o2-5.5
hc-0847
With tps disconnected.
co-1.45
co2-12.4
o2-2.69
hc- 0557
I really dont want to get rid of the car, had it nearly 6 years, buts its getting dangerous when dying at roundabouts.
Old Nov 3, 2012 | 05:57 PM
suffolk04's Avatar
suffolk04
Used a code reader today, but keeps reading code 11, all systems ok. Would this mean the fault isn't with the ecu?
Why would the engine run smoother with the tps disconnected? What sensor does it use Instead?
Old Nov 3, 2012 | 06:28 PM
hotwhiteorion's Avatar
hotwhiteorion
Could be iscv try disconnecting it see if it makes a difference
Old Nov 3, 2012 | 07:48 PM
suffolk04's Avatar
suffolk04
If I disconnect it, the revs die to around 700rpm, when connected goes up to around 1200, then settles a t around 1000. So think its working
Old Nov 3, 2012 | 10:03 PM
johnnysash's Avatar
johnnysash
I have said it before and I will say it again.... An Internet forum is a bloody nightmare for diagnosing these sort of things..... . However in a bid to help, I will throw in my 2p worth.
Have you tried the road speed sensor? It sounds like an intermittant fault.
Have you tried cleaning the iscv with carb cleaner?
Have you tried cleaning inside the throttle body with carb cleaner?
Does it sound like there are any air leaks anywhere?
Finally..... You might receive more replies in the tech q and a area as the Xr room is a bit dead of late.....
Good luck mate
Old Nov 4, 2012 | 07:29 AM
suffolk04's Avatar
suffolk04
No air leaks, but will try cleaning the iscv and throttle body sometime today.
Should the efi have a speed sensor? Not got one on mine, just the cable and the red plastic speedo drive
Old Nov 4, 2012 | 04:04 PM
suffolk04's Avatar
suffolk04
Good luck mate
Cleaned out throttle body and iscv. Retested engine running test with code reader, came up code 13. Not sure what that means, in the tester manual, says air vane temp sensor,autodata says coolant temp sensor, and some websites says iscv did not respond.
Think cleaning out iscv has killed it somehow, when it's disconnect, engine speed stays the same, and when connected, engine speed doesn't change
Old Nov 7, 2012 | 06:02 PM
suffolk04's Avatar
suffolk04
Changed iscv and coolant temp sensor, genuine ford £130. Car doesn't cut out anymore, but idles lumpy, and back fires at constant speeds.
Can I get this thread moved to tech q and a? Love the car, but can't afford to keep chucking money at it.
Chas
Sep 21, 2015 08:57 PM
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 17, 2015 12:21 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
