Ford XR Range This forum is for discussion of all things pertaining to the Ford XR Range of cars.
Mk4 front hub
Old Apr 7, 2012 | 02:01 PM
Gregg1101's Avatar
Gregg1101
Default Mk4 front hub
Hi guys,
My first post so please be kind.
Having issues with my front hub. The retaining screw snapped off and I have been trying to drill it out but I have buggered it up. I know you don't really need it but it is just a pain when you come to put the wheels back on and have to line 3 holes up to get the nuts in.
My question is, I have heard that the mk5 has the outer bolts on the rotor part and you can use it on the mk4. Is this correct? If so, is a straight swap? I an guessing it is just the rotor part which needs to be changed and not the whole hub. This would be ideal if it does work and I would be able to scrap the stupid retaining screw rotor.
Many thanks
Gregg
Old Apr 7, 2012 | 06:02 PM
xrmalin's Avatar
xrmalin
Hi Gregg have you thought of converting your hubs to studs ? Its easy enough to do and stops plenty of faffing when it comes to getting your wheels on.
Old Apr 8, 2012 | 09:58 AM
Gregg1101's Avatar
Gregg1101
Hi mate. Yes that is what I would like to do. Can I use the mk5's ones? The only reason why I ask is that I don't have a welder and for me it would be easier to just get the part and swap it over.
Old Apr 9, 2012 | 01:36 PM
xrmalin's Avatar
xrmalin
You don't have to weld anything you just drill the holes out slightly in your hub, buy some thing like these
http://www.edsmotorsport.co.uk/ford-...tuds-107-p.asp
And press them in to the holes you've drilled out.
If you do a search on here there should be a guide some where
Old May 5, 2012 | 11:18 AM
JasonXR2Racer's Avatar
JasonXR2Racer
Mk5 hubs are slightly different as the CV's are shaped differently on the end
Steve Escos
Ford Focus ST Parts for Sale
Oct 19, 2015 05:34 PM
FlashRS
13
Aug 31, 2015 06:02 PM
C2 MAK
Aug 20, 2015 09:46 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
