propshaft couplings
propshaft couplings
Hi,
I have the early type thick (~47mm) propshaft coupling (Sierra cosworth 4wd) what i need to replace. I did some research here and found that Ford does not sell it any more.
However i have found a STC brand coupling listed for Escort V 1.6 petrol with almost the same dimensions minus the centre bearing:
https://www.ebay.co.uk/itm/Coupling-...955f%7Ciid%3A1
Before i order this part is there a way it will not fit for some reason? Has anyone had any experience with this part?
thanks
thanks
I fear that you MIGHT get some vibration with that as the centre does not have any support. I managed to buy a second hand donut in good nick. some people have solid mounted theirs but MarkK on here thinks that could break the gearbox and others have changed the prop to one piece.
Do let us all know if you try this and what the outcome is.
I wonder if the likes of Powerflex could be persuaded to make a new part if they though there would be a market for them?
There is also a type of CV joint that can be used but I forget the name of them.
320 bhp
13
04-05-2007 05:21 PM
GT2
14-10-2005 10:04 PM
