4-caliper + handbrake rear?
How have you solved the problem with the handbrake back when you switched to larger calipers?
I'll switch to the 330 front and 300 rear and must replace calipers front and rear, but must also retain the hand brake wire.
Is there anyone that uses both 4-calipers and original calipers only for handbrake? How did you mount it?
Regards/Jonas
Regards/Jonas
I think there are pics on the Reyland site using the original caliper for handbrake
Yes, I have seen that. But I don't understand how those brackets could make me use both a aftermarket caliper and original for the handbrake.
Regards
Regards
I MUST replace. I'm gonna make a registration on the car, and need to change all brake system. But I can use the original caliper for the handbrake.
Alternatively, a caliper with handbrake from start.
In front I got Brembo 4pot and 330mm discs. No abs, just double headcylinder.
Regards
Regards
dingla rs
10-07-2016 06:02 AM
original
15-09-2012 06:41 PM
Mad Matt
27
13-05-2009 10:46 PM
redrsmk5
Ford Escort RS Cosworth
28-10-2007 09:49 PM
antony215
11-10-2006 07:19 AM
