2WD drive shafts
2WD drive shafts
They look exactly the same both ends
But can someone confirm if they should be fitted a certain way round
Thanks
Thanks
Morning ,
They are exactly the same both ends so as a result you can fit as you wish. But if a shaft has been driven in certain way i.e. - turned anti-clockwise it's life you should fit it the same way as the structure of the metal will be stressed / set in that direction.
Hope this makes some sort of sense.
Tim.
Tim.
zetaboostboy522bhp
12-11-2009 09:48 PM
kennert
26-09-2004 07:26 PM
